I'm using Calibre and it seems that it uses xdg-open to open files. This, even when tried in terminal, only opens nautilus and the file is selected, but not opened. It doesn't matter if I try to open .cbz or .pdf.
This seems fine: /usr/share/applications/defaults.list
application/x-cbr=evince.desktop
application/x-cbz=evince.desktop
Sure when I open the file in Nautilus it opens, but this approach is quite annoying.
César
  • 807
DeusIX
  • 73
I found a solution to the same problem in an answer for another askubuntu question: https://askubuntu.com/a/39602/1943
Basically you have to set Thunar as default file manager for xfce:
http://ubuntuforums.org/showpost.php?p=10884462&postcount=16
Once you do that, xdg-open and gnome-open will avoid using exo-helper to open nautilus. Somehow gnome and xfce get interwoven.
EDIT: the downside is that now Thunar opens instead of nautilus when opening folders. But I find it less frustrating, on the other hand I could uninstall xfce4 if I really don't want it
mkm
  • 3,239
Source: Bug #751374 “Dash won't open files anymore” : Bugs : “unity-place-files” package : Ubuntu
See comment #27 in the source thread. I modified the original commands to use sed.
  1. Remove mime entries containing exo as a normal user.
    sed -i '/exo/d' ~/.local/share/applications/mimeapps.list
  2. Update mime desktop database.
    update-desktop-database ~/.local/share/applications
This helped me fix my own Ubuntu/XFCE install without removing XFCE. You may have to modify more (see source thread), but these commands fixed it in my install.
From what I gather in the source thread, the bug may have been fixed for clean installs.
ENG_ACK
  • 35
