Possible Duplicate:
Files lens and xdg-open only open nautilus but not the correct applicatiion
In 12.04, since yesterday the behavior of the dash in Unity has changed.
Previously (and I assume it is the default choice), when selecting a file in the dash, the file was automatically opened with its corresponding application. Now, the folder containing the file is opened in Nautilus instead.
(I have to mention that I have installed XFCE)
How do I revert to the first behaviour ?
Thanks.
Alkalyzer
  • 347
I found someone having a similar problem on the Ubuntu forums. And this problem was linked to the presence of an installation of the XFCE desktop environment.
Because it was also my case, I used a solution suggested in this thread, which simply consists in erasing all traces of XFCE installation.
I opened a terminal and enter the following command :
sudo apt-get remove `dpkg -l | grep xfce|awk '{print $2}'`
Now, I can't use XFCE anymore but the normal behavior of the dash has been restored.
Alkalyzer
  • 347
