38
I've attempted to install utorrent on 14.04 using the Terminal and attempting to install libssl 0.9.8, but with no success. Also, this utorrent version is V3.3 and is located in my Downloads. I've already attempted the post which mine was a dupe of (How to install uTorrent step by step? )
Sharky
  • 383
Install uTorrent Server 3.3
Step 1: Download latest uTorrent Server from here
Note: (You need to download uTorrent Server for 13.04, also works for Ubuntu 14.04)
Step 2: Extract uTorrent Files
  • Launch terminal (with Ctrl+Alt+T or search Terminal in dash and click to open it)
    Change directory to Downloads folder
    cd ~/Downloads/
  • Extract uTorrent files to the /opt directory
    sudo tar -xvzf utserver.tar.gz -C /opt/
Step 3: Set Permission
  • Set permission on uTorrent-server folder
    sudo chmod -R 755 /opt/utorrent-server-alpha-v3_3/
Step 4: Set Symbolic link
  • Run the command to link uTorrent server to the /user/bin directory.
    sudo ln -s /opt/utorrent-server-alpha-v3_3/utserver /usr/bin/utserver
Step 5: Start uTorrent
  • Run the following command in the Terminal
    utserver -settingspath /opt/utorrent-server-alpha-v3_3/
Note: If you get an error about libssl.so package missing, then
  • Run the command below to install it:
    sudo apt-get install libssl0.9.8:i386
    then try starting it again.
Step 6: Log into uTorrent
  • Open Firefox/Chrome and browse to the URL
    localhost:8080/gui
  • The username is admin and leave the password field empty
Original post from www.sysads.co.uk
Note2 : If libssl0.9.8:i386 isn't working, try libssl0.9.8, if that also doesn't work, you probably need libssl1.0.0 (Ubuntu 16.04) .
null
  • 161
αғsнιη
  • 36,350
