i downloaded Utorrent for windows I downloaded Wine application in my Ubuntu OS. I ran utorrent using Wine application. It worked well. But then, after i had downloaded the files.
When i click on "open Folder", it opened a folder with downloaded files. But i am not able to open any of them. I also cannot able to copy, move the files from that folder where it was downloaded.
{ Since the utorrent has default Save location as C:\user\downloads.. it has assumed it that way., now i m not able to retrieve it back]
Please HELP!
Thanks in advance.
So I guess your problem is that you can't find the downloaded files from your non-Wine environment.
By default wine creates a hidden folder in your /home called .wine. This is called your WINEPREFIX. Naturally (as with everything in linux) this location can be changed, but I'll assume that you left it at the default.
So you have your WINEPREFIX in the /home/<user>/.wine folder. If you look into it you will see a drive_c folder which is exactly that, your "C:". In that folder you will have an exact copy of a Windows filesystem.
So your file's paths will be something along the lines of /home/<user>/.wine/users/<user>/dowloads/.
Wolfer
  • 2,214
