I have no idea what I'm doing when it comes to this. I downloaded the .tar.gz file from the Utorrent website and extracted it to a folder I made in the Home directory. I tried executing the executable file but nothing seemed to happen.
Asked
Active
Viewed 840 times
You have to change the permissions of the executable file.
Suppose you extracted .tar.gz to a directory utorrent in home directory and the executable file is named as utorrent-1.0 and it is in utorrent directory.
You will have to execute following set of commands for executing utorrent-1.0
Open terminal (Crtl+Alt+T) and execute following commands.
chmod +x ~/utorrent/utorrent-1.0
The above command will add executable attribute on utorrent-1.0 file
cd ~/utorrent && ./utorrent-1.0
The above command will execute utorrent-1.0
The example is arbitrary, replace utorrent with name (or path) of directory where you extracted files and replace utorrent-1.0 with executable file located in the said directory.
Faizan Akram Dar
- 4,569
- 1
- 25
- 31
