I have a SanDisk 16GB USB drive that is not being detected by Ubuntu 14.04 but is detected by Windows 7.
lsusb detects it but sudo fdisk -l or blkid doesn't.
Even GParted and Disks don't detect it.
Here's some terminal output:
lsusb
Bus 002 Device 006: ID 12d1:1003 Huawei Technologies Co., Ltd. E220 HSDPA Modem / E230/E270/E870 HSDPA/HSUPA Modem
Bus 002 Device 004: ID 0781:5576 SanDisk Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 002: ID 1a2c:0021 China Resource Semico Co., Ltd Keyboard
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 002: ID 04f2:b070 Chicony Electronics Co., Ltd
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
tail -f /var/log/syslog
Sep 10 22:28:22 xhakz kernel: [ 2203.587319] usb 2-2: USB disconnect, device number 4
Sep 10 22:28:25 xhakz kernel: [ 2206.212045] usb 2-2: new high-speed USB device number 7 using ehci-pci
Sep 10 22:28:25 xhakz mtp-probe: checking bus 2, device 7: "/sys/devices/pci0000:00/0000:00:1d.7/usb2/2-2"
Sep 10 22:28:25 xhakz kernel: [ 2206.344889] usb 2-2: New USB device found, idVendor=0781, idProduct=5576
Sep 10 22:28:25 xhakz kernel: [ 2206.344895] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Sep 10 22:28:25 xhakz kernel: [ 2206.344897] usb 2-2: Product: Cruzer Facet
Sep 10 22:28:25 xhakz kernel: [ 2206.344900] usb 2-2: Manufacturer: SanDisk
Sep 10 22:28:25 xhakz kernel: [ 2206.344902] usb 2-2: SerialNumber: 4C532000030522108444
Sep 10 22:28:25 xhakz mtp-probe: bus: 2, device: 7 was not an MTP device
usb-devices
T: Bus=02 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 7 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=0781 ProdID=5576 Rev=01.26
S: Manufacturer=SanDisk
S: Product=Cruzer Facet
S: SerialNumber=4C532000030522108444
C: #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=200mA
I: If#= 0 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=(none)
I don't know what to do anymore to get it detected and I don't want to format it as it contains important data.
I backed up my data in another laptop, formatted the drive in Windows 7 but still it's not recognized. The funny thing is that Windows 7 detects it and uses it fine but it's not detected in Ubuntu except by the lsusb command. Weird.
EDIT
Requested command output:
sudo lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 149.1G 0 disk
├─sda1 8:1 0 1.5G 0 part
├─sda2 8:2 0 74.4G 0 part
├─sda3 8:3 0 1K 0 part
├─sda4 8:4 0 32G 0 part /media/kagz/New Volume
├─sda5 8:5 0 1.9G 0 part [SWAP]
└─sda6 8:6 0 39.4G 0 part /
sr0 11:0 1 1024M 0 rom
sudo lshw
http://paste.ubuntu.com/8332788/
uname -a
Linux xhakz 3.13.0-35-generic #62-Ubuntu SMP Fri Aug 15 01:58:01 UTC 2014 i686 i686 i686 GNU/Linux
EDIT 2
Something interesting:
The USB DOES NOT work in guest mode but WORKS in live session mode. All running Ubuntu 14.04.
Re-installing is not an option.
EDIT 3
Other USB's don't work, this is a problem with the system not the USB.
