I am trying to access a USB pendrive on my system having OS Ubuntu 16.04.
I could not see the drive symbol. I have searched for the solution and have tried this solution: Sandisk USB not detected by Ubuntu 14.04 but detected by Windows 7
But it doesn't worked for me. Even the USB drive is not getting accessed on any Windows Platform too. It shows a message to format the drive recursively and do not let me access the drive on Windows.
But my primary issue is with respect to Ubuntu as I always use this OS only.
I have seen that when I insert the pendrive the drive menus blink, but I could not see the drive.
Kindly, help me how to make the drive visible and even workable for me. I do not want to format the drive as it has a much important data and there is no backup currently. Please let me know your advice. If anyone has the same problem and have solved it previously, kindly let me know the answer.
After Typing command dmesg
[79536.075479] sd 18:0:0:0: [sdb] Assuming drive cache: write through
[79536.081868] sd 18:0:0:0: [sdb] Attached SCSI removable disk
This is the output I get but I do not see the drive in the list after opening folder structure. On windows system it shows that is is write protected too. i don't know why this happening. Do share your thoughts.
