14
I was trying to install Ubuntu 14 (64-bit) on a Aspire V5-531, preinstalled Win 8. In the bios I can flag:
boot mode UEFI, secure boot DISABLE
  • in this case the neither installation USB card nor cd rom start
boot mode in Legacy Mode
  • I can install Ubuntu 14, but grub doesn't work (yes, I used boot repair, but it doesen't work properly).
Braiam
  • 69,112
I resolved it this way:
  • let boot mode UEFI enabled, secure boot enabled
  • in BIOS added the USB boot file of the distribution I want to install as trusted for executing:
My BIOS is Phoenix SecureCore Tiano Setup
  • Under Boot I flag Boot Mode UEFI
  • Secure Boot ENABLE
  • Under SECURITY select: Select an UEFI file as trusted for executing
  • in Available File System I select fs0:$nameofmyusbkey
  • Select [EFI]
  • Select [BOOT]
  • Select BOOTx64.EFI
  • Give it the name whateveryouwant then, using tab, select YES.
  • so I go to the Boot option, then put whateveryouwant as first in the Boot priority order
  • then I was able to start Ubuntu installation in UEFI mode! :)
WARNING!
Before I did all this, I freed the space for my partitions under Windows 8. I read so many guide about UEFI and UEFI install (I give advice to do it!), and tried in several ways. That was the only way I was able to do what I wanted.
Zanna
  • 72,312
