I am having windows 7 installed on my laptop. I tried to make it dual boot by installing the 32 bit Ubuntu 14.04.01 but at the end of installation it gives an error message.
Unable to install.Permission denied.for more details check log at location
c:\users\local\temp\wubi-14.04-rev286.log.
I was doing the installation using the Live CD but couldn't do it then i tried using boot-able pen-drive but the result was same.
My system configuration is as below.
Dell Vostro 3560
with i5-3230M processor @ 2.6 Ghz 4 GB Ram 500GB HDD,1 GB AMD radeon HD 7670M DDR3
OS windows 7 Ultimate 64 bit version.
Kindly Help me to resolve this issue.
αғsнιη
  • 36,350
If it's a newer one that uses UEFI, disable secure boot and set it to legacy mode. This should resolve any issues you have, as it'll then act like a BIOS. All Wubi does is add a disk image containing Ubuntu, an "mbr" file containing GRUB, and a boot entry in BCD.
If it uses a BIOS, then perhaps your issue is with the administrator privileges. Give Wubi admin and try again.
Hope this helps.
