  • The installation is being carried out alongside Windows 10.
  • UEFI is enabled
  • Secure boot is disabled
  • Live USB works fine on other PCs
  • The UBUNTU Iso checksum has been verified too
  • Fast boot and hibernate are also disabled
Each time I try to restart the PC with the boot preference having Live USB at the top, I get nothing but Windows starts to load. Please help me fix this.
EDIT 1: The laptop is Acer Aspire 5, with 4gigs of memory, 1 TB of HDD, Nvidia MX940, Intel Core i5 6200u
EDIT 2: I was able to boot through the F12 boot menu finally and also succesfully installed Ubuntu. But now I have a bigger problem. Grub is not loading, neither is it showing in the bios boot menu!
I also have an Acer Aspire E5 and had the same problem. Follow these steps:
They assume that you are installing Ubuntu, but might also be required for booting from a Live USB
  1. Make sure your UEFI is up to date.
  2. In UEFI, you must set a supervisor password. Once the supervisor password is set, some new menus are accessible.
  3. Enter the "Select an UEFI file as trusted for executing" menu. It will allow you to declare the newly installed Ubuntu boot image as trusted on your laptop.
  4. Select EMMC >> EFI >> Ubuntu and select the file shimx64.efi. You will be prompted to give it a name of your choice (which will appear in the F12 boot options).
  5. Type the name press Enter and then "Yes" should be highlighted.
  6. Press enter again. Restart the computer without any boot disk and tap F12 during the boot process.
  7. You should now get the boot option menu with the name you chose.
  8. You can change the boot order in UEFI now so that it boots directly to the Grub screen.
  9. Either disable the supervisor password, or save it in a secure place.
