I can't find .bash_profile in Ubuntu 14.04 in my /home/user directory. I used the ls -a command to see the .bash_profile, but there isn't such a file.
Ubuntu uses ~/.profile .
you can create your .bash_profile in Ubuntu but then .profile will not be read.
If we read .profile content :
cat ~/.profile
output
# ~/.profile: executed by the command interpreter for login shells.
# This file is not read by bash(1), if ~/.bash_profile or ~/.bash_login
# exists.
So use ~/.profile instead of ~/.bash_profile
- 39,152
When invoking a login shell bash will looks for its config files in this order:
[0] ~/.bash_profile
[1] ~/.bash_login
[2] ~/.profile
After finding the first one, it stops looking for the others so if there is a .bash_profile in my $HOME bash will not look for .bash_login and .profile anymore.
From these three file names, Ubuntu by default uses .profile you can rename it to .bash_profile if you like:
mv ~/.profile ~/.bash_profile
Now if we open a new bash shell using bash -l, su - $USER, sudo -u $USER -i or any other commands that runs bash as a login shell, ~/.bash_profile will get sourced.
Important to note:
What I have talked about till now only applies to Bash itself, when you are logging into the system from a GUI, the display manager is responsible of sourcing the correct files.
Ubuntu uses gdm3 as its display manager, if we take a look at: /etc/gdm3/Xsession we can see that none of the files will get sourced except: .profile:
# First read /etc/profile and .profile
for file in /etc/profile "$HOME/.profile"; do
if [ -f "$file" ]; then
source_with_error_check "$file"
fi
done
so if you are using a GUI to login, keep the file under .profile name otherwise you might miss some variables and settings in your environments.
I guess the better option is creating a symlink to .profile:
ln -s ~/.profile ~/.bash_profile
Now your data lives in .profile, gdm doesn't miss anything, bash loads .bash_profile which is actually .profile, and by editing each of them you get the same result.
Missing .profile?
If you don't have .profile then grab a copy of it from here:
cp /etc/skel/.profile ~/.profile
or
# Remember the note above
cp /etc/skel/.profile ~/.bash_profile
- 57,256
That means the file does not exist. But, you can create the file and bash executes/sources the file if bash is invoked as a login shell. So evertime you login via a shell (for example via ssh).
If you want the content to execute everytime you open a terminal, then you should modify the .bashrc file instead.
- 28,186
Top answer to use ~/.profile instead of ~/.bash_profile did not work for me.
Modifying .bashrc worked
Just:
vim ~/.bashrc
Note: I'm using Ubuntu WSL.
- 1,156
- 6
- 15
- 21
- 150
If you mean the .bashrc you will find it in your home folder. If it isn't there, you can copy it from the /etc/skel folder to your home folder.
If you need some more information on this subject, please visit stefaan lippens page.
- 1
