Everyday I install caffe, it works, then I restart my the system and I get the error :
ImportError: No module named caffe
So I fix it by
import sys
sys.path.append('/home/shubham/caffe/python')
And everything works (only until I exit my ipython) no matter what my env variables are upto.
On checking my env variables CAFFE_ROOT & PYTHONPATH are always stuck to this directory: /home/shubham/Desktop/dir/vgg_face_caffe/ no matter how much I change them. Although python always seems to work even with the PYTHONPATH set to a directory where there is no python installation at all.
My questions are :
How do I fix up the caffe path so I don't get the import module error ?
Why do the environment variables not making sense ? That is, how is python working with the wrong PYTHONPATH path and yet caffe doesn't work when I set the right path ?
And why do they keep changing by itself ?
I am on ubuntu 16.04
Thank you for reading !
EDIT: just realized PYTHONPATH and CAFE_ROOT are always same as the directory in I am in. Still need help.
