182
I feel stupid asking, but I can't seem to find the answer to this anywhere. I'm trying to follow these instructions to edit my bash prompt, but there is no .bashrc in either my user directory (~/.bashrc), or in my home directory, or in the main file system directory.
There is no .bashrc in /etc/ (there is a bash.bashrc, however).
Do I create a .bashrc file in my user or home directory? Is there a better, more recent set of instructions for modifying the bash prompt?
Charo
  • 3,681
JeanSibelius
  • 3,682
11 Answers11
194
Don't forget it is a hidden file inside your home directory (you would not be the first to do a ls -l and thinking it is not there).
Do a:
ls -la ~/ | more
There should be a .bashrc on the first page. If not just create it with:
vi ~/.bashrc
and add in the lines you need to add into it.
Permissions of my .bashrc are:
-rw-r--r--  1 discworld discworld  3330 Mar 10 16:03 .bashrc
(chmod 644 .bashrc to make it rw r r).
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
Rinzwind
  • 309,379
46
User specific, hidden by default.
~/.bashrc
If not there simply create one.
System wide:
/etc/bash.bashrc
Alen
  • 606
18
There is a .bashrc in every user's home folder (99.99% of the time) as well as one system-wide (which I don't know the location of in Ubuntu).
The quickest way to access it is nano ~/.bashrc from a terminal (replace nano with whatever you like to use).
If this is not present in a user's home folder the system-wide .bashrc is used as a fallback as it is loaded before the user's file. You could simply copy and paste it (with root permissions of course), but a .bashrc is not entirely essential (it may be required to make things work. I haven't found out) at a user level as it mostly overrides the system-wide one with user-specific tweaks. You could write your own though.
The main components for that users may tweak are PS1 (the Bash prompt defaults to display user@localhost:pwd $) and aliases as well as setting a color prompt and maybe PS2 (busy state message).
14
Use gedit ~/.bashrc, it will allow you to modify ~/.bashrc using gedit.
kos
  • 41,268
adonese
  • 141
It is hidden because of the '.' it starts with.
list it with
ls -al
or enable "show hidden files" under the view menu in nautilus (Ctrl-H will also do the trick).
You can edit it with your favorite text editor from your home directory e.g.
cd
to go to your home directory then:
emacs .bashrc
haziz
  • 3,067
If .bashrc is not in your home folder, even after you list the hidden files, you can copy it from:
/etc/skel/.bashrc
heemayl
  • 93,925
eaykin
  • 151
if not in home directory, you can just copy from /etc/bash.bashrc, and make it source for your terminal, by typing in your terminal source .bashrc from your home directory after copying.
Mudit Kapil
  • 2,081
Use nano ~/.bashrc to open and edit the .bashrc file. (This will create the file if it does not yet exist)
Bashrc file is a hidden file inside the home directory. It is actually, give the path directions.
And those are wanted to edit .bashrc file, try this command gedit ~/.bashrc instead of this ~/.bashrc .
This command gedit ~/.bashrc directly take you to the text editor, where you can edit it easily, as you know.
Just one note: after you made your alias in bashrc, you need in your terminal to write following command in order that your aliases work:
source .bashrc
Personally, whenever I install Linux anew, I add some aliases finding an appropriate place in .bashrc E.g.
#My aliases
alias shut='shutdown now'
alias x='exit'
alias update='sudo apt-get update'
Etc. You get the idea.
Zed Pi
  • 31
If you use encryption and work from the command line you might not see it as one need to mount the real home-dir first (in contrast to in the graphical UI where this is done automaticallu) by the command:
ecryptfs-mount-private
(I had the same question and stumbled upon this question; but found my answer in the readme instead)
