I'm trying to debug a strange issue with my ~/.bash_profile, and I'd like to be able to see if there are any errors / etc printed when it's run. Is there some log or such somewhere that contains the stdout and/or stderr of the login shell process? Thanks!
The error only happens in the very first root login shell, not when re-executed or re-run in other contexts - it has something to do with that particular context / environment. So standard tricks of tee / piping output / etc from an invoking terminal don't work.
stdout and stderr will appear in the terminal everytime you do a login. You must log out and back in again for the changes in your profile to take effect. A further explanation of the use of ~/.bash_profile is provided here on Ask Ubuntu with a good answer
stumblebee
  • 4,379
Tbh I didn't try myself, but I'm pretty sure standard output and error are the terminal it's running on, as soon as the process starts. You can check by putting a command such as echo "Hello world" in your .bash_profile...
NovHak
  • 779
To debug a bash script you have several options, and some of these are even more effective than redirecting stdout/stderr.
Activate trace
You could add to your ~/.bash_profile (creating a trace only for specific parts of your script) with
set -x          # activate debugging from here
<commands>
set +x          # stop debugging from here
Also, set -v prints shell input lines as they are read, and set +v deactivates this. With this alone you will likely catch the problem.
Redirect trace
Use Bash Variable BASH_XTRACEFD
If set to an integer corresponding to a valid file descriptor, Bash will write the trace output generated when ‘set -x’ is enabled to that file descriptor. This allows tracing output to be separated from diagnostic and error messages. The file descriptor is closed when BASH_XTRACEFD is unset or assigned a new value. Unsetting BASH_XTRACEFD or assigning it the empty string causes the trace output to be sent to the standard error. Note that setting BASH_XTRACEFD to 2 (the standard error file descriptor) and then unsetting it will result in the standard error being closed.
So you would use
exec 5> ~/bash_profile_ouput.txt
BASH_XTRACEFD="5"
<commands>
unset BASH_XTRACEFD
Print line numbers
Use Bash Variable LINENO (and BASH_LINENO, BASH_SOURCE and/or FUNCNAME in more elaborate cases)
echo "Executing ${LINENO}"
<commands>
Redirect stdout/stderr
Combine command exec with redirection, and possibly tee. See answers here, which also include other methods/"tricks" than using exec.
Related:
  1. https://stackoverflow.com/questions/44249890/pipe-bash-stdout-only-in-debug-mode
  2. https://unix.stackexchange.com/questions/334382/find-out-what-scripts-are-being-run-by-bash-on-startup
  3. https://unix.stackexchange.com/questions/155551/how-to-debug-a-bash-script
