How can i make a windows installation USB? I already have the iso file, and i need to install windows 7 dual boot as i have to install my company software.
I am using netbook.
I used unetbootin, but failed.
Any quick and easy solution?
You have to install a software for this purpose known as winUsb using following commands
sudo add-apt-repository ppa:colingille/freshlight sudo apt-get update sudo apt-get install winusb
else download a .deb file from this link and then run following command
sudo dpkg -i [filename].deb if you get any dependency problem or errors due to dependency problems use following command to resolve it
sudo apt-get install -f
check this for more info on .deb packages
you can check this link
for more details on installation and winusb check this website
Chinmaya B
  • 7,022
  • 27
  • 43
If you have the iso image you can use the dd command in terminal, check this link: Burning a ISO image to USB device
Danilo
  • 127
