I am not able to find trash anywhere. Can you please tell me a command or anything like that to empty the trash using terminal ?
You can use the rm command:
rm -rf ~/.local/share/Trash/*
The rm command removes (deletes) files or directories.
-f, --force Ignore nonexistant files, and never prompt before removing.
-r, -R, --recursive Remove directories and their contents recursively.
The trash folder is found at: $HOME/.local/share/Trash
Be careful how you use the rm command - the files aren't sent to a trash can where you can undelete them, so it's not easy to undo.
- 119,640
- 39,152
After you sudo apt install trash-cli, you can do
trash-empty
More interesting details about trash handling below and in the man page.
trash (1) - Command line trash utility.
trash-empty (1) - Empty for Command line trash utility.
trash-list (1) - List trashed files.
trash-put (1) - Command line trash utility.
trash-restore (1) - Restore for Command line trash utility.
trash-rm (1) - Removes files matching a pattern from the trash can
You are looking for the $XDG_DATA_HOME/Trash directory. The trash directory is defined in the "Desktop Trash Can Specification" of the freedesktop site. This variable is normally not available in the terminal windows, hence you will need for trash-empty. This command follows all the specification of the Freedesktop.org and it's intelligent enough to find out where the Trash is. You will need to install it first.
There are other tools for this, like gvfs-trash --empty which can also send items to the Trash can.
- 69,112
With trash-cli installed type trash-empty I've used this successfully to empty the trash across different drives and numerous locations.
to install trash-cli type
sudo apt-get install trash-cli
Or you could use this script to do it for you.
- 36,752
Please note, ~/.local/share/Trash/* might not be the only location that stores the trashed files, so removing that path is not enough if you have other partitions that also have a trash folder.
If you want to empty the trash in all available partitions, you can use the following command to empty the trash:
gio trash --empty
gio is provided by glib2, which is used by most GTK-based applications, and the gio binary should be available out-of-the-box in most of the cases if you are using a desktop environment. If not, you can install it via:
apt-get install libglib2.0-bin
- 173
