31
I need to automate desktop configuration via Puppet, virtual terminal or ssh.
Unfortunately, invocation of gsettings via ssh or virtual terminal gives:
gsettings set org.compiz.core:/org/compiz/profiles/unity/plugins/core/ hsize "4"
(process:29520): dconf-WARNING **: failed to commit changes to dconf: Cannot autolaunch D-Bus without X11 $DISPLAY
When I set the $DISPLAY with export DISPLAY=:0.0 it gives another error:
(process:29862): dconf-WARNING **: failed to commit changes to dconf: Could not connect: Connection refused
What can I do?
The key is to set the DBUS_SESSION_BUS_ADDRESS environment variable.
On this thread I found the following script, that helps to get the correct value of that variable. It requires name of the process, that is running on the desktop, on which we want to change the dbus settings. (There can be more than 1 running graphical sessions in parallel). Lets call it discover_session_bus_address.sh
#!/bin/bash
# Remember to run this script using the command "source ./filename.sh"
# Search these processes for the session variable
# (they are run as the current user and have the DBUS session variable set)
compatiblePrograms=( nautilus kdeinit kded4 pulseaudio trackerd )
# Attempt to get a program pid
for index in ${compatiblePrograms[@]}; do
    PID=$(pidof -s ${index})
    if [[ "${PID}" != "" ]]; then
        break
    fi
done
if [[ "${PID}" == "" ]]; then
    echo "Could not detect active login session"
    return 1
fi
QUERY_ENVIRON="$(tr '\0' '\n' < /proc/${PID}/environ | grep "DBUS_SESSION_BUS_ADDRESS" | cut -d "=" -f 2-)"
if [[ "${QUERY_ENVIRON}" != "" ]]; then
    export DBUS_SESSION_BUS_ADDRESS="${QUERY_ENVIRON}"
    echo "Connected to session:"
    echo "DBUS_SESSION_BUS_ADDRESS=${DBUS_SESSION_BUS_ADDRESS}"
else
    echo "Could not find dbus session ID in user environment."
    return 1
fi
return 0
With this script we can do the following, assuming that unity process is running on the desktop, on which we want to apply our settings:
. ./discover_session_bus_address.sh unity
And things should work OK.
-1
I have a POST-Install script that sets my gsetting. Because I run the script as sudo the EUID is 0, there fore I have to find the $RUID (Real User ID).
here is my approach:
#!/usr/bin/env bash
# Get the Real Username
RUID=$(who | awk 'FNR == 1 {print $1}')
# Translate Real Username to Real User ID
RUSER_UID=$(id -u ${RUID})
# Set gsettings for the Real User
sudo -u ${RUID} DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/${RUSER_UID}/bus" gsettings set org.gnome.desktop.interface clock-show-date false
exit
caracal
  • 147
