I'm having a weird problem and was hoping maybe someone out there might be able to give me some insight. Kind of at a loss.
On Linux Mint using Nemo which has a tendency to crash every once in a while with the annoying side-effect of shifting a bunch of my desktop icons. I thought I'd just write a quick script that would dump the locations of all my icons to a text file once a day, and then another to reposition them back where they are supposed to be.
It works perfectly when I run it manually, but not when it runs through cron.
I have figured out that the problem comes down to gvfs-info. Basically, I use the command:
gvfs-info -a 'metadata::nemo-icon-position' /path/to/file
which will produce:
metadata::nemo-icon-position: 220,682
in the output.
gvfs-info, however, needs to communicate with the dbus-daemon to get the metadata because it's actually stored in ~/.local/share/gvfs-metadata/. It can't access the dbus-daemon when it's being spawned from cron (or sudo or ssh for that matter)—a fact I discovered here and here which proposes a possible solution.
Following that solution, I can successfully execute from the terminal:
dbus-launch --exit-with-session /path/to/myscript.sh
and it works as expected. However it still produces the same output without the metadata. I've tried a lot of permutations of where I called dbus-launch and in combinations with 'su user' to ensure it's actually running as my user, but I guess I just don't understand what's going on here very well.
Anyone have any thoughts?
Shaav
  • 31
@steeldriver's comment was exactly what I needed (Thank you!).
I lifted the below from How to change Gsettings via remote shell and it was exactly what I needed!
PID=$(pidof -s nemo)
QUERY_ENVIRON="$(tr '\0' '\n' < /proc/${PID}/environ | grep "DBUS_SESSION_BUS_ADDRESS" | cut -d "=" -f 2-)"
export DBUS_SESSION_BUS_ADDRESS="${QUERY_ENVIRON}"
I used 'nemo' because I know it would be running in my desktop environment.
Shaav
  • 31
