134
I just installed Ubuntu 14.04 and I can't mount my exFAT HDD.
I get the following error:
Unable to access “SeagateHDD”
Error mounting /dev/sdb1 at /media/me/SeagateHDD: Command-line `mount -t "exfat" -o "uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000,iocharset=utf8,namecase=0,errors=remount-ro,umask=0077" "/dev/sdb1" "/media/me/SeagateHDD"' exited with non-zero exit status 1:
stdout: `FUSE exfat 1.0.1
stderr: `ERROR: `Operating Systems' has invalid checksum (0x281c != 0x2450).
I installed exfat-utils and exfat-fuse using apt-get but no luck. I also tried the repository ppa:relan/exfat but I got:
 fuse-exfat : Depends: fuse-utils (>= 2.7) but it is not installable
Can anybody give me a hint? All my backed up data is on that HDD.
EDIT:
The output of $ sudo apt-cache policy exfat-fuse is:
exfat-fuse:
  Installed: (none)
  Candidate: 1.0.1-1
  Version table:
     1.0.1-1 0
        500 http://ppa.launchpad.net/relan/exfat/ubuntu/ trusty/main amd64 Packages
Tried it on a Linux Mint and had the same problem. Also tried mounting it on a Mac and it worked perfectly so the data is not corrupted.
EDIT2:
It appears it was a problem with my HDD which apparently I unplugged from the USB port without unmounting and it had a checksum error. What I did was I plugged it on my Mac and it automatically did a fsck_exfat disk check which fixed the problem and I could load it on Ubuntu as well. I think a similar thing could be achieved on Ubuntu as well, but I don't know which tools to use to do so.
na-no.
  • 856
  • 24
Iuliu
  • 1,473
5 Answers5
204
Installing the below packages alone will auto-mounts your exFAT formatted drives ,
sudo apt-get install exfat-fuse exfat-utils
Or you may try to mount it manually after installing the above packages,
sudo mkdir /media/exfat
sudo mount -t exfat /dev/sdxx /media/exfat
/dev/sdxx - your exfat partition.
In Ubuntu 14.04, exfat-fuse and exfat-utils packages are available in Universe repository. So enable this repository inorder to install these two packages on Ubuntu 14.04.
sudo add-apt-repository universe
And don't forget to update all repositories,
sudo apt-get update
Avinash Raj
  • 80,446
how about compile from source ?
# wget http://sourceforge.net/projects/fuse/files/fuse-2.X/2.9.3/fuse-2.9.3.tar.gz
# tar -xzvf fuse-2.9.3.tar.gz
# cd fuse*
# ./configure
# make
# make install
ajaaskel
  • 103
Just add the following PPA and install from the PPA:
sudo apt-add-repository ppa:relan/exfat
sudo apt-get update
and reboot your computer.
karel
  • 122,292
  • 133
  • 301
  • 332
I had the same issue and I tried fuse and everything recommended in the forums with setting up/verifying fuse and trying to mount it manually but no luck.
The issue happened because I ejected the disk before unmounting it when my macbookpro got struck. So I used MacBook's Diskutility to repair it and it started mounting again in ubuntu with all my data intact.
achie
  • 111
Here is how I just made a perfect and clean installation of support for the exFAT file system type, to access my new micro SD card, in my Ubuntu 12.04 (64-bit, running on a Thinkpad T60, dual core, 2.0GHz and 4Gb ram, running on an internal Kingston SSD drive). All one need do is install Synaptic Package Manager, possibly by using the default package manager. Then, in the search box, type exfat. When I did this, only two items came to view in the list: exfat-utils and exfat-fuse. Now, put a check mark in both of these boxes by clicking with the mouse pointer (actually, I ticked the top one, and I got a message that both are required. When I closed the pop-up message, both boxes were ticked for me). Then, click apply. When the installation completed (very quickly and easily), I then opened my file manager. In the upper left I clicked the micro SD card that was previously not mountable. Immediately, the contents of the card displayed for the first time, since formatting the card to exFAT. I only had a test text file in it at the time, to help me determine what was going on. Now, everything is perfect, and I don't have to manually do anything (like mount and unmount). It is all automatic, like with cards formatted to FAT32. VOILA !!! All is well, now. Enjoy ! NOTE: I had reformatted my 512Gb generic micro SDHC class 10 card in Windows XP 32-bit, because at the time it couldn't be done with my Ubuntu system of then, prior to the above installation of exFAT support.
