i am using Ubuntu 16.04 lts on a Thinkpad t440s. The build in Cardreader always worked well till a point when it did not recognize cards and i had to reenter them several times. One SD card broke. But then it worked well for a long time. Now a different Problem occurs.
1) When i try to copy a whole lot of files on the SD Card (128GB/exfat) i takes a lot of time and the transferrate is XX kbytes/s. If the amount is to high or i copy very large files it interrupts the procedure with I/O ERROR.
2) When i try the exact same SD Card in an external USB Reader everything works fine! The transferrate is about 20mb/s and i get no errors. So the SD Card is fine, i also checked badblocks and fsck: No Errors.
3) When i try another SD Card (32gb/fat32) works fine.
 output of mount, (not working 128 gb):
/dev/mmcblk0p1 on /media/crubuntu/SDXC type fuseblk (rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096,uhelper=udisks2)
output of mount (working, 32gb):
/dev/mmcblk0p1 on /media/crubuntu/3134-6333 type vfat (rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,showexec,utf8,flush,errors=remount-ro,uhelper=udisks2)
The Card reader: 14cd:6700 Super Top Card Reader
Everything seems like there is an Software error or something. I already tried: Reinstall usidsk2, Card Formatted as fat32, formatted as ntfs.
if any addition Information is needed, i will provide.
I would be glad to hear from you guys.
thanks!
