17
Could you please help me ?
On my old Ubuntu 13.10 I was able to run Juniper VPN (on Firefox only) using a workaround which requires you to install the missing 32libs and IcedTea (32bits).
However, I recently upgraded from Ubuntu 13.10 to 14.04 (both 64 bits) and my Juniper VPN does not work anymore because it fails during startup showing the following message:
"Please ensure that necessary 32 bit libraries are installed. For more details, refer KB article KB25230"
"Setup failed. Please install 32 bit Java and update alternatives links using update-alternatives command. For more details, refer KB article KB25230"
For some odd reason, it seems the 14.04 upgrade do not work anymore with the openjdk-7:386 and consequently the Juniper VPN as well.
Any ideas ? Thanks
You could try the suggestion in this post: Juniper setup on 12.04
Update for 14.04 Trusty Tahr (64-bit)
First run with Network Connect on 14.04 resulted a failure and Network Connect just complained about missing 32-bit libraries. My NC version is 7.4R6. I did have all the libraries installed and openjdk-7-jre:i386 installed.
Digging a little bit deeper revealed that Network Connect is using update-alternatives listing to decide if 32-bit jre is installed.
/usr/sbin/alternatives command not found
Command = /bin/sh -c /usr/sbin/update-alternatives --display java 2>&1 | grep -v "/bin/sh:" | grep ^/ | cut -d " " -f 1 | tr " " " "
However it's looking update-alternatives from /usr/sbin/ and there seems to be no symlink pointing to the right directory like 13.10 had. So adding symlink to /usr/sbin/ helped.
$ sudo ln -s /usr/bin/update-alternatives /usr/sbin/
Just for completeness, as well as having to install a 32-bit JRE, I also had to follow the info here: http://itfuzz.blogspot.de/2013/11/juniper-network-connect-and-ubuntu-1310.html and run this command on 14.04:
sudo apt-get install libstdc++6:i386 lib32z1 lib32ncurses5 lib32bz2-1.0 libxext6:i386 libxrender1:i386 libxtst6:i386 libxi6:i386
I must already have done this on 13.10 as it worked then, but on 14.04 the Network Connect window just closed. This fixed the problem.
mike
  • 206
I just set up a VPN connect to juniper using MadScientist's msjnc script that wraps around a binary (ncsvc) from the juniper linux client .jar
The ncsvc binary does not require java at all, so this is somewhat the neatest solution I could find.
The script can be found here: http://mad-scientist.us/juniper.html
noleti
  • 4,103
  • 28
  • 27
Due to some wrong upgrades, I couldn't launch vpn. Finally this blog helped me.
http://www.lyricalsoftware.com/blog/juniper-vpn-working-in-ubuntu-14-04-trusty/
Chitrasen
  • 134
In my case the following steps work:
  1. Install Oracle Java 8
    sudo apt-add-repository ppa:webupd8team/java
    sudo apt-get update
    sudo apt-get install oracle-java8-installer
  2. Download the tar ball of 32 bit Java 8 from here
download jre-8uXXX-linux-i586.tar.gz
XXX - version (in my case 131, change in following steps 131 to the version that you downloading)
  1. Move the file to /usr/lib/jvm/
    sudo mv /home/envy/Downloads/jre-8u131-linux-i586.tar.gz /usr/lib/jvm/
  2. Extract the file
    cd /usr/lib/jvm/
    sudo tar xvf jre-8u131-linux-i586.tar.gz
  3. Change it to root ownership
    sudo ls -ld /usr/lib/jvm/jre1.8.0_131/
    chown root.root -R /usr/lib/jvm/jre1.8.0_131/
  4. Update the alternatives link for Java
    sudo update-alternatives --install /usr/bin/java java /usr/lib/jvm/jre1.8.0_131/bin/java 10
  5. Ensure that the default Java version is still 64 bit
    7a. If Java default changed to 32 bit version.
    sudo update-alternatives --config java
  6. Install the standard 32 bit libraries
    sudo dpkg --add-architecture i386
    sudo apt-get install libstdc++6:i386 lib32z1 lib32ncurses5 libxext6:i386 libxrender1:i386 libxtst6:i386 libxi6:i386
source here
