I really need some help troubleshooting this.
I've been here already:
How to install Juniper VPN on Ubuntu 14.04 LTS?
http://mad-scientist.us/juniper.html
The client opens and then closes. It runs fine from the command line but doesn't connect to anything.
Firewall is down:
user@box:~$ firewall
Chain INPUT (policy ACCEPT 21770 packets, 3492K bytes)
num pkts bytes target prot opt in out source destination
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
Chain OUTPUT (policy ACCEPT 22171 packets, 1501K bytes)
user@box:~$
As far as I can tell all of the 32 bit packages are installed. I'm seeing no Exceptions or warnings that suggest one might be missing. Do I know all the places to look for these? No, probably not, but I have:
user@box ~ $ sudo apt-get install libc6:i386 zlib1g:i386 libgtk2-perl libwww-perl
Reading package lists... Done
Building dependency tree
libwww-perl is already the newest version.
libgtk2-perl is already the newest version.
zlib1g:i386 is already the newest version.
libc6:i386 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 9 not upgraded.
...and also:
sudo update-alternatives --config java
[sudo] password for user:
There are 2 choices for the alternative java (providing /usr/bin/java).
Selection Path Priority Status
* 0 /usr/lib/jvm/java-7-openjdk-amd64/jre/bin/java 1071 auto mode
1 /usr/lib/jvm/java-7-openjdk-amd64/jre/bin/java 1071 manual mode
2 /usr/lib/jvm/java-7-openjdk-i386/jre/bin/java 1070 manual mode
Press enter to keep the current choice[*], or type selection number:
When started from CLI:
user@box:~$ sudo msjnc --connect --root
Enter your password or PID+SecureID:
Connecting to vpn.company.com (company) ................................. failed
The Juniper Network Connect VPN session did not start.
Also:
/usr/lib/jvm/java-7-openjdk-i386/jre/bin/java -classpath /home/user/.juniper_networks/network_connect/NC.jar NC ncui -h vpn.company.com -n -t -x
The above command pops up the window and it does prompt for a password but it drops dead when I enter it. What I'm afraid of is that there might be an additional password that I don't know of, similar to Cisco VPN networking.
The update-alternatives link has been created in /usr/sbin.
