I have Ubuntu x64 and trying to install Juniper network connect.
Installed 64bit jre/jdk, icedtea and 32bit jre
 sudo apt-get install openjdk-7-jre icedtea-7-plugin
 sudo apt-get install openjdk-7-jre:i386
command update-alternatives --config java shows that java-7-openjdk-i386 is intalled and selected
 Selection    Path                                            Priority   Status
  0            /usr/lib/jvm/java-7-openjdk-amd64/jre/bin/java   1071      auto mode
  1            /usr/lib/jvm/java-7-openjdk-amd64/jre/bin/java   1071      manual mode
* 2            /usr/lib/jvm/java-7-openjdk-i386/jre/bin/java    1070      manual mode
But when I'm trying to install network connect recieved following error:
"Setup failed. Please install 32 bit Java and update alternatives links using update-alternatives command. For more details, refer KB article KB25230 "
These steps worked fine on Ubuntu 12.04 x64 and I'm wondering why it doesn't work on 14.04
David Foerster
  • 36,890
  • 56
  • 97
  • 151
adding symlink to /usr/sbin/ helped.
sudo ln -s /usr/bin/update-alternatives /usr/sbin/
solution from following article: How to install Juniper VPN on Ubuntu 14.04 LTS?
Thanks
Just to add another note to help anyone having problems...
The best thing you can do for debugging problems is to turn on the Java console in IcedTea by running itweb-settings - this will show all the errors in the juniper script.
In my case the script was running 'java -version' and grepping for 'Java version' but I was using openjdk which outputs 'openjdk version'. So I installed the Oracle jre 8 and created a symlink to the plugin in my .mozilla/plugins directory.
Tom
the juniper documents say to keep 64bit as a default
unfortuneatly the doco is behind their firewall (an account is free)
http://kb.juniper.net/InfoCenter/index?page=content&id=KB25230&actp=search&viewlocale=en_US&searchid=1400682188393
