30
I really like that synapse application launcher, but there seems to be no way of installing it in ubuntu 14.04. Any ideas why? Or does anyone know how I could get it?
Braiam
  • 69,112
Elysium
  • 11,142
8 Answers8
31
A bug has been filed on launchpad about that.
It seems, though, that the program's testing PPA now supports 14.04: Synapse Bleeding edge
EDIT:
To install from the PPA above, do the following in a terminal - [Ctrl+Alt+t]
sudo apt-add-repository ppa:synapse-core/testing
(press Enter-key when prompted to continue)
sudo apt-get update
sudo apt-get install synapse
Synapse should now be installed.
NOTE: It is not recommended that you use a bleeding edge version of a software application as they may (and often do) contain game breaking bugs. My advice is that you keep checking Ubuntu's software repository and revert to a stable version as soon as one is made available.
v2r
  • 9,707
migdsb
  • 523
Synapse was removed of Debian since was seriously bugged and blocked the removal of Vala, this also affects new Ubuntu installation since Ubuntu imports from Debian.
You can use a PPA or compiling from sources but you wont have Ubuntu support to solve any bug encountered.
The changelog of the package confirms this.
Braiam
  • 69,112
I've been looking for Synapse too, since I installed Ubuntu 14.04, and just found these links:
For 32-bit PC:
https://launchpad.net/ubuntu/trusty/i386/synapse/0.2.10-2ubuntu3
Look for "synapse_0.2.10-2ubuntu3_i386.deb (473.5 KiB)" under Downloadable files.
For 64-bit PC:
https://launchpad.net/ubuntu/trusty/amd64/synapse/0.2.10-2ubuntu3
Look for "synapse_0.2.10-2ubuntu3_amd64.deb (475.9 KiB)" under Downloadable files.
Attention! I still haven't tested them, for I'm at work right now. As soon as I get home, in the evening, I'll test it, then I come back here to say if it works or not. In the meantime, if anyone tests it, please, let us know if it works, OK?
I hope this works. I really miss Synapse. Unity Dash sucks! :)
brunces
  • 659
  • 17
An alternative to Synapse which is available in the Software Center is called Launchy. It's not quite as nice as Synapse but does the trick and doesn't seem to break anything.
Gnome-do will do.
sudo apt-get install gnome-do
You need to use the Bleeding Edge PPA:
It contains Synapse for Ubuntu 14.04.
(Original answer not mine. I found it here: How to add ppa repositories?). It works!
raulceuta
I have found several users having problems with the bleeding edge version of synapse. Sometimes it doesn't run. I have included a .deb file to share which is version 0.2.10, I have not had any issues with this version on several machines. Link below to download.
http://xellink.com/2015/01/31/lubuntu-guide-synapse-application-launcher/
xellink
Synapse is no longer officially maintained; so in my eyes there is not much sense in trying to somehow get it up and running on your system. You might be better of using alternatives, like "launchy" or "kupfer".
GhostCat
  • 2,165
