83
I have one computer running Ubuntu 10.04, and is running Vino, the default VNC server.
I have a second Windows box which is running a VNC client, but does not have any X11 capabilities. I am ssh'd into the Ubuntu host from the Windows host, but I forgot to enable VNC access on the Ubuntu host.
On the Ubuntu host, is there a way for me to enable VNC connections from the Ubuntu commandline?
Update:
As @koanhead says below, there is no man page for vino (e.g. man -k vino and info vino return nothing), and vino --help doesn't show any help).
Braiam
  • 69,112
11 Answers11
35
I also wanted to enable vino with the command line without going in vino-preferences.
When I started /usr/lib/vino/vino-server, it says that I didn't have desktop sharing service enabled.
With Unity gconftool isn't usable anymore. We have to do it via gsettings.
So, first, enable vino :
gsettings set org.gnome.Vino prompt-enabled true
Then start vino :
Now you can access remotely to your computer.
If you want to see all configs available for Vino :
gsettings list-keys org.gnome.Vino
30
Short Answer:
gconftool-2 --set --type=bool /desktop/gnome/remote_access/enabled true
as the accepted answer mentions, if vino isn't started on the remote machine, use
Long Answer and more info:
A subset of the settings for the current built-in remote access server (vino) can be seen, as mentioned, from vino-preferences. A complete list of gconf flags can be seen with the gconf-editor command, listed under /desktop/gnome/remote_access . You can see also the other remote_access keys with this command (or a variation on it):
gconftool-2 -a /desktop/gnome/remote_access
(For whatever reason, -R will also work.)
You can also get the schema key documentation via the --long-docs arg.
E.g., for the alternative_port key :
gconftool-2 --long-docs /desktop/gnome/remote_access/alternative_port
       The port which the server will listen to if the
       'use_alternative_port' key is set to true.
       Valid values are in the range from 5000 to 50000.
So, for example, here's how to change default port via command line:
gconftool-2 --set --type=bool /desktop/gnome/remote_access/use_alternative_port true
gconftool-2 --set --type=int /desktop/gnome/remote_access/alternative_port 5999
gconftool will give you the keys under a given directory. Here is the 'remote_access' section:
 use_upnp = false
 vnc_password =
 authentication_methods = [vnc]
 network_interface =
 require_encryption = false
 disable_background = false
 enabled = true
 use_alternative_port = false
 mailto =
 disable_xdamage = false
 lock_screen_on_disconnect = false
 icon_visibility = always
 view_only = false
 prompt_enabled = true
 alternative_port = 5900
Here is how to list all the schema docs under /desk/gnome/remote/access (via command-line /bin/bash):
for key in ` gconftool-2 -a /desktop/gnome/remote_access | awk '{print $1}'  ` ; do echo $key ; gconftool-2 --long-docs /desktop/gnome/remote_access/$key ; done
belacqua
  • 23,540
28
Just running
should do the job.
Once you have access to your server, I would recommend that you add it to Autostarted Apps so it is always started.
You'll probably like change some settings with :
vino-preferences
be very careful when you run vino-preference on a remote machine, if you uncheck "Allow other users to control your desktop", you won't be able to check it back.
or to edit :
~/.gconf/desktop/gnome/remote_access/%gconf.xml
Here a sample file :
<?xml version="1.0"?>
<gconf>
    <entry name="vnc_password" mtime="1289267042" type="string">
        <stringvalue>cXdlcnR5</stringvalue>
    </entry>
    <entry name="view_only" mtime="1289262982" type="bool" value="false"/>
    <entry name="prompt_enabled" mtime="1254965869" type="bool" value="false"/>
    <entry name="authentication_methods" mtime="1289267034" type="list" ltype="string">
        <li type="string">
            <stringvalue>vnc</stringvalue>
        </li>
    </entry>
    <entry name="enabled" mtime="1289263574" type="bool" value="true"/>
</gconf>
Be careful, the password is base64 encoded. For this file, the password is qwerty. I see on some forum that people have change it successfully, but I had issue with it.
Here an online base64 encoder :
http://www.motobit.com/util/base64-decoder-encoder.asp
26
On Ubuntu 14.04, I found the following variation worked for me:
export DISPLAY=:0
gsettings set org.gnome.Vino enabled true
gsettings set org.gnome.Vino prompt-enabled false
gsettings set org.gnome.Vino require-encryption false
If this doesn't work, your X session might be running on something other than :0, so a quick ps aux | grep X should show a :1 or :2
Taeram
  • 360
14
Why, for the love of all that is good in this hard world, is there no man entry for vino or vino-server or for any of the commands listed in dpkg -L vino's output? For that matter, why should any package at all be installed on an Ubuntu system, ever, which omits a man page at least for the relevant commands? Ok, rant over. The best answer I've found so far is here: http://ubuntuforums.org/archive/index.php/t-266981.html
I really hope this helps, and I hope that in future the Ubuntu community documents all these orphaned commands. "Ease of use" does not mean abandoning the command line, and it certainly does not mean abandoning easily accessible documentation. </grumble>
koanhead
  • 6,547
10
This doesn't seem to work remotely via ssh due to errors about the display and so on. Here's what I did:
export DISPLAY=:0.0 && /usr/lib/vino/vino-server
Mostly works now!
Rinzwind
  • 309,379
I was able to set a fresh Ubuntu 16.04 install from a remote ssh connection with the following script:
#!/bin/bash
export DISPLAY=:0
read -e -p "VNC Password: " -i "ubuntu" password
dconf write /org/gnome/desktop/remote-access/enabled true
dconf write /org/gnome/desktop/remote-access/prompt-enabled false
dconf write /org/gnome/desktop/remote-access/authentication-methods "['vnc']"
dconf write /org/gnome/desktop/remote-access/require-encryption false
dconf write /org/gnome/desktop/remote-access/vnc-password \"\'$(echo -n $password | base64)\'\"
dconf dump /org/gnome/desktop/remote-access/
sudo service lightdm restart
The quoting is important for any of the string settings (single ticks inside quotes). For dconf to be able to write it needs access to XWindows, so that's why the export DISPLAY part is needed. I think you still need to be logged in to the desktop on the actual Ubuntu machine to connect with VNC after this. The dump command is just there to confirm all the settings took hold, you don't really need that.
Optionally you may want to do this if you want to keep the display up all the time:
dconf write /org/gnome/desktop/screensaver/lock-enabled false
dconf write /org/gnome/desktop/screensaver/ubuntu-lock-on-suspend false
dconf write /org/gnome/desktop/session/idle-delay "uint32 0"
Pablo Bianchi
  • 17,371
I had that same issue with xubuntu after 18.04 upgrade. First install vino. Mine was removed on upgrade without any notice. Also even after installing vino, the command vino-preferences doesn't work.
Here is an easy workaround:
  • Install dconf-editor
     sudo apt install dconf-editor
  • then open it and go to /org/gnome/desktop/remote-access/require-encryption and turn off encryption.
There are also several other remote options you can set in dconf-editor. However until you install vino, the remote-access doesn't show in dconf-editor.
I hope someone can explain what happened to vino-preferences.
Pablo Bianchi
  • 17,371
For anyone using Linux Mint 15, I got this all to work on my MintBox2 by doing the following. I can now run the MintBox 2 entirely headless with: ssh + vino + Tight VNC.
Type into putty via ssh connection to the LinuxMint MintBox2 machine:
sudo su
[enter your root password]
echo $DISPLAY
export DISPLAY=:0.0
startx &   }This loads up LinuxMint on screen as "root" user
[press the return key again to get back to BASH prompt]
Now, if you like (this isn't necessary) on a LinuxMint terminal (i.e. not on putty) type:
echo $DISPLAY
=> You get an output of :1 [i.e. this caused me a lot of trouble to figure out i.e this is not 0:0 !!!!!!!!!!]
Now, go back to putty and type:
echo $DISPLAY
export DISPLAY=:1
=> It now loads & you can use window 7 Tight VNC Viewer to access Linux Mint etc
I hope this helps some one out there...
CMP
  • 191
One step that is not often mentioned is that you need to enable auto login, you can do so by editing the following file:
sudo vi /etc/gdm3/custom.conf
And adding the following lines (or modifying existing vales):
[daemon]
AutomaticLoginEnable=true
AutomaticLogin=myuser
Then restart.
watsonmw
  • 121
-1
gsettings list-recursively org.gnome.Vino   # Lists keys and values, recursively
gsettings reset-recursively org.gnome.Vino  # Reset all keys under the given SCHEMA
Then check this.
Pablo Bianchi
  • 17,371
