I installed Ubuntu 18.04 desktop with minimal installation on my mac mini. It however doesn't come with remote desktop.
I already have ssh access. So how can I, through terminal, enable and configure VNC remote access from both the local IP address (192.168.1.x) and its FQDN?
I want to use the default display manager and desktop interface for Bionic Beaver.
Notes:
  • I don't have any monitor attached
  • I want to use the default window manager (xorg)
  • I want to use the default desktop environment
  • I did minimal installation when installing Ubuntu Desktop
cclloyd
  • 361
To your working ssh setup, add a vnc server like x11vnc to your server and a viewer like xtightvncviewer to your remote machine. For outside the local network, ensure you have a passthrough for your ssh (port 5900 will be tunneled, so nothing special needed for it). X should be running on the server, but no existing login is needed (you will connect to the login screen). No other special services needed on the server.
From the remote, use ssh to start the x11vnc server, and tunnel port 5900 back to the remote (assumed to be on ...131 on the local network). In a terminal type:
ssh -t -L 5900:localhost:5900 192.168.1.131 "sudo x11vnc -localhost -create -auth guess  -display :0"
The output should indicate a successful connection. Leave this terminal and in another, start the vnc viewer on the (tunneled local port 5900):
xtightvncviewer -encodings RRE -bgr233 localhost::5900
The encodings and option improve performance for me, but are optional. A new window should open with the server login screen displayed. Login to the desktop you set up.
If you want to leave the server program running over multiple invocations of the viewer, you may use the -forever option, but with the above, the server will close the x11vnc program when the viewer exits.
ubfan1
  • 19,049
sudo apt install vino
Then go to Settings >> Share
Vino's already installed on some versions of Ubuntu, but just incase (e.g. minimal install):
If connecting from an unencrypted VNC client (e.g. MacOS), you can disable encryption:
gsettings set org.gnome.Vino require-encryption false
To set the password to 1234 and allow VNC style authentication
gsettings set org.gnome.Vino authentication-methods "['vnc']"
gsettings set org.gnome.Vino vnc-password $(echo -n '1234'|base64)
To disable the manual confirmation prompt that prevents a connection until you allow it:
gsettings set org.gnome.Vino prompt-enabled false
To start vino on the display server that's on the physical machine:
export DISPLAY=:0.0
/usr/lib/vino/vino-server
Disclaimer: Some of the above will lower the security of the machine. It's intended to gain remote access temporarily. Please use proper security protocols as needed.
Thanks to various posts by @proximous:
tresf
  • 1,072
Sorry for late reply, please do update if you are already able to get it resolved and if yes, how.
Question before we go ahead, how were you able to get SSH access on minimal installation ?
However with that being said the issue with 3.9.2 version is that it no longer comes with standalone preference dialog box, refer to bug 700070. In short, you now do need access to GNOME Control Center to start vino for GNOME
If that is not available there are multiple ways you can still get remote access, you can go with X11 and access via XRDP, here is great reply on forum for your ref
Else, The easiest solution is to install the package vino38, which provides the latest version with the preferences dialog, accessible via the vino-preferences command. URL for vino38 is here
Refer to another great answer on how to configure VNC from command line it is for old version of ubuntu, but i am sure the commands should still work.
That is the extent of my knowledge on vino for GNOME. i hope it helps. Good luck
