14
I have a 17" laptop with 1600x900 resolution, but it's not enough to open windows side by side. I'm wondering if i could zoom out (or any other solution) windows (or the whole desktop). Is there a solution on xserver or on the WM to make this happen?
By the way, compiz zoom out plugin don't let you to zoom out more than 1:1 which is not enough, I want to zoom out more the same way as spreading all windows with unity-tweak-tool.
Rmano
  • 32,167
Disclaimer: I do not know if it works for all graphic drivers. Intel driver here, in 13.04.
First of all get the normal screen you have active:
xrandr --current
My output is:
Screen 0: minimum 320 x 200, current 1024 x 600, maximum 32767 x 32767
LVDS1 connected 1024x600+0+0 (normal left inverted right x axis y axis) 220mm x 129mm
   1024x600       60.0*+   65.0
   800x600        60.3     56.2
   640x480        59.9
VGA1 disconnected (normal left inverted right x axis y axis)
Ok, it is LVDS1. Now for example to zoom out at half linear dimension:
xrandr --output LVDS1 --scale 2x2
The whole screen should zoom out. Now I have:
(0)asus-romano:~/research/reviews% xrandr --current
Screen 0: minimum 320 x 200, current 2048 x 1200, maximum 32767 x 32767
LVDS1 connected 2048x1200+0+0 (normal left inverted right x axis y axis) 220mm x 129mm
   800x600        60.3     56.2
   640x480        59.9
So the systems thinks it has a 2048x1200 screen. Very useful for crappy programs that thinks you have a gazillion pixel space and do not offer scrollbars in some option windows...
To go back:
xrandr --output LVDS1 --scale 1x1
(You can use 1.5x1.5, too). Look at man xrandr for a lot of fancy things.
Oops. There seem to be a bug in which the extended video zone is not reachable: https://bugs.launchpad.net/ubuntu/+source/xorg-server/+bug/883319 and upstream https://bugs.freedesktop.org/show_bug.cgi?id=39949
A workaround for this is to specify the desired larger area as a --panning option, e.g.:
 xrandr --output LVDS1 --scale 2x2 --panning 2048x1200
It will not cause any actual panning, since the whole large area fits on the screen due to the scaling.
Zoltan
  • 767
Rmano
  • 32,167
There is an option of scaling out the desktop upto 1:4 and scaling in upto 1:0.5. This option is available in System settings -> Display. However, this is not in a very good shape at the moment, have seen issues where it breaks unity.
So this is recommended only if its absolutely necessary and other solutions don't work out.
jobin
  • 28,567
