I have a dodgie old tv I want to use as a monitor, but its underscanning and no option to change in tv menu. I'm loosing the whole menu bar up top and most of the launcher
I have googled a lot and found two possible approaches to solve using xrandr
1 set underscan as per this page https://ubuntuforums.org/showthread.php?t=2141776&page=2&p=12643066#post12643066
2 Scale output xrandr scale monitor output by default
Can I zoom out windows or scale the whole desktop?
Problem is when I try either of these options I get the same error message
$ xrandr --output HDMI-1 --set underscan on
X Error of failed request: BadName (named color or font does not exist)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 11 (RRQueryOutputProperty)
Serial number of failed request: 34
Current serial number in output stream: 34
$ xrandr --output HDMI-1 --scale 0.9x0.9
X Error of failed request: BadValue (integer parameter out of range for operation)
Minor opcode of failed request: 26 (RRSetCrtcTransform)
Value in failed request: 0x40
Serial number of failed request: 33
My xrandr output is
~$ xrandr
Screen 0: minimum 8 x 8, current 2646 x 768, maximum 16384 x 16384
eDP-1 connected primary 1366x768+1280+0 344mm x 193mm
1366x768 60.0*+
1360x768 59.8 60.0
1024x768 60.0 60.0
960x720 60.0
928x696 60.1
896x672 60.0
960x600 60.0
960x540 60.0
800x600 60.0 60.3 56.2
840x525 60.0 59.9
800x512 60.2
700x525 60.0
640x512 60.0
720x450 59.9
640x480 60.0 59.9
680x384 59.8 60.0
576x432 60.1
512x384 60.0
400x300 60.3 56.3
320x240 60.1
DP-1 disconnected
HDMI-1 connected 1280x720+0+48 708mm x 398mm
1280x720 60.0*+ 50.0 59.9
1920x1080 60.0 50.0 59.9 30.0 25.0 24.0 30.0 24.0
1920x1080i 60.1 50.0 60.0
1024x768 60.0
800x600 60.3
720x576 50.0
720x576i 50.1
720x480 60.0 60.0 59.9
720x480i 60.1 60.1
Currently running 1280x720 because I get a bit less chopped off, but would prefer 1080 which is the monitors native res.
Any advice would be very welcome at this stage. I'm not great with CLI so very detailed instructions would be nice, then I might learn whats going on as well as copy pasting commands.
