16
I have used the wpa_passphrase command and I get something like this:
network={ ssid="blahblah" #psk="moreblahblah" psk=d5e532ecca53ea963e5b3b5521bb3682c53fcf5b6d55f15622027145c795b661 }
I need to copy that "psk=[long string]" to my wpa_supplicant.conf file. How can I select it in order to copy it? And then what command do I use to copy it? Such that in my favourite text editor I can press a paste command to paste it? (ps. I don't have a mouse )
Jorge Castro
  • 73,717
6 Answers6
24
if you have a touchpad though, highlight the text and press Ctrl + Shift + C to copy ...
the following resources describe how to copy/paste using keyboard only -- screen/byobu:
How do I integrate Byobu's copy-buffer with the X clipboard?
http://www.samsarin.com/blog/2007/03/11/gnu-screen-working-with-the-scrollback-buffer/
Copy and Paste in Scrollback mode (screen/byobu)
  • Enter scrollback mode: Ctrl+A+[ or in byobu also F7
  • Move the cursor to the start of the text you want to copy, hit spacebar
  • Move the cursor to the end of the text you want to copy and hit enter
  • To paste text, hit Ctrl+A+] or Alt+Insert
type
  • 3,247
Try this:
wpa_passphrase | awk '/psk/ {print $4}' >> wpa.supplicant.conf
Command should take out the "psk=d5e532ecca53ea963e5b3b5521bb3682c53fcf5b6d55f15622027145c795b661" part and copy it to the end of your wpa.supplicant.conf file. Try changing $4 to $3 or $2 if you don't get the right part of the wpa_passphrase command.
May be not perfect but a workaround. May be you could write the output in a file then go into the file remove unnecessary text and using cat you could append it to wpa_supplicant.conf
Basically your workflow would be:
command > rough
nano rough here delete the unnecessary text and keep just the necessary ones i.e psk
sudo sh -c "cat rough >> wpa_supplicant.conf"
Or may be you could use vim to yank the required text choosing it in visual mode.
P.S. Someone with good knowledge of sed would give you a easier solution than this I think.
sagarchalise
  • 24,306
Of course the most common way to do this would be to use a mouse or other pointing device (such as a touchpad). Although it's somewhat excentric, it's possible to copy text without a mouse. (You may of course have a valid reason not use a pointing device.) Check out xclip, as in this answer. Thus you could use:
wpa_passphrase | xclip -sel clip
loevborg
  • 7,414
The next sed command will fetch the key (which consists of characters from the hexadecimal set) from the output of wpa_passphrase and put it in a temporary file pass.
wpa_passphrase | sed 's/.*psk=\([0-9a-f]*\).*/\1/' > pass
As you do not have a mouse, you cannot just select and copy it. We'll use the nano texteditor for inserting this pass:
nano wpa_suppliciant.conf
Move to your desired location using your arrow keys and press Insert. Enter the name of the file you've just created, pass, followed by an Enter. Quit & save the result by pressing Ctrl + X and confirm it by entering Y followed by an Enter.
Lekensteyn
  • 178,446
You can setup a keybinding in byobu to be able to send the text selected in byobu's buffer into the X clipboard.
Add the following to ~/.byobu/keybindings
# Add cool line to make copying to x clipboard possible.
# This binds C-a b to copy screen's copy buffer to the system clipboard.
bind b eval writebuf 'exec /bin/sh -c "xsel -i < $BYOBU_RUN_DIR/printscreen"'
Then after using the usual F7, move, space to start select, move, enter to save to buffrer, then you can use C-a b (Ctrl-a, then b) to save it to the clipboard
(Based on https://dodoincfedora.wordpress.com/2012/06/23/integrating-byobuscreens-copy-buffer-with-xgnome-clipboard/)
