My intention is to copy many pages of my terminal output to a file for logging purpose. The trick to copy screen content does not work well with me. It requires too many keys to remember, and even if I remember it, it is still slower than Shift+F7 to capture the whole thing.
However, Shift+F7 opens a new window tab name "PRINTSCREEN*" using my environment $EDITOR, and if I choose to save it (using vim or emacs), it will save to something like /tmp/shm/byobu-username-RanDomNameDir/.
I will have to navigate to my $PWD to save the file. The path is most of the time very deep and long. Is there a way I can change so that the temporary buffer of byobu's PRINTSCREEN default to $PWD?
Update:
Why not just use redirection?
Many suggested this. The answer is, I know about redirection. But this is not the case to use it. I do interactive with the terminal to explore various direction before script the work and redirect output to file "properly". My question is about tweaking configuration of byobu's Shift+F7 command. The sole purpose of it is to serve the use cases where screen redirection did not happen. So no need to talk about screen redirection please.
Use Linux embedded script utility. For example, to capture everything from terminal to file capture.log in the current directory (get it with pwd), do:
script capture.log
To stop capturing just type exit or press CTRL+D. More information on script and its options:
man script
Remark. Script utility output files contain raw control characters, thus to read it use less with -r and -R options, i.e.
less -rR capture.log
To clean output files from raw control characters use the command:
cat capture.log | perl -pe 's/\e([^\[\]]|\[.*?[a-zA-Z]|\].*?\a)//g' | col -b > capture-clean.log
The last command removes raw control chars from capture.log file and creates plain text file capture-clean.log.
Additionally read How to clean up output of linux 'script' command.
Bob
  • 2,563
After some testing, I decided that it's best to fix from the root: not byobu, but tmux. Some nice developer at tmux community made a patch. And things works perfectly now: https://github.com/tmux/tmux/issues/1400
