I installed Ubuntu today and since the first start up I have a problem with the mouse cursor.
It starts randomly disappearing and flickering a lot.
I have searched for a solution on Google and here but didn't find anything.
I had the same problem. You can fix it manually.
Open System Settings > Displays.
In the Displays window, you will see an Unknown monitor.
Click it and disable it.
Possible cause 1:
Screen settings: resolution and refresh rate.
Can be checked (On KDE) under systemsettings5 then display and monitor
Possible cause 2:
Screen compositor: it could be caused by the sale-method/rendering-backend/tearing-prevention those settings can be changed (On KDE) under systemsettings5, display and monitor then compositor... apply new settings and compare
Possible cause 3:
Display server mis-configuration: you can regenerate the display server config file with X -configure or similar but first make a copy of /etc/X11
Possible cause 4:
System failure, crash, reboot: on system failure especially for systems equipped with SSD you may loose important files; Files under directories like /home/user/, /etc/ or /usr/ can cause serious damages, as these directories contain important settings/packages files for different aspect of the desktop. usually when a file is lost after a crash, the file may be completely deleted or zeroed, you can then search for file with zero size and check out if important file are corrupted with the command find /etc -size 0 -print (this is for /etc) you can also check packages integrity for missing/modified file, on rpm based system it's done with the command rpm -Va you would then reinstall the broken package.
A common situation in this case is loosing the file /etc/X11/xorg.conf or one of the config file under /etc/X11/ responsible for the display server; If recovering the file is not possible the config can be regenerated with X -configure or similar command
Possible cause 5:
Mis-configuration of user files under /home/user... you can verify this by login with an other user... to fix it eventually delete and recreate the user (after backup)
Possible cause 7:
Graphic drivers, you need to check if you are using the proper graphic driver and or try a different version of the used driver, usually this often happen with nvidia graphical cards.
Other...
The listed situations are not the only possibilities of failure.
Source: Linuxhacks.org
Disclosure: I am the owner of Linuxhacks.org
2020 - Ubuntu 18.04
The problem here was because of I have Dell's laptop and Dells's Monitor, there isn't any "unknown display".
The Ubuntu wasn't recognizing the laptop as "built in".
After setup everything and restart the laptop, all works fine.
I was able to fix the issue by changing my monitor setup using randr. It turned out that my second screen had a rather large offset to the first one (instead of being directly adjacent). My best guess is that this creates a large mostly unused framebuffer that also covers the area between the screens, which may be problematic?
You can either use a tool like arandr to place the screens without a gap in a GUI or run xrandr on the command line like so
xrandr --output HDMI-1 --left-of DP-1
(replace your respective monitor outputs, you can find out their name by running xrandr without arguments)
In my case, using Ubuntu 22.04, I was able to resolve the problem by switching off Fractional Scaling. Settings then Screen Display then turn off Fractional Scaling
I ran, from within 16.04, the command:
sudo apt-get upgrade
and it seems to have appeased the pointer, so far. I had instability, especially over the Chrome browser tabs.
