This question has been asked many times here and in other forums. I tried everything I could find, nothing works.
I'm trying to use my NVIDIA GT540M on Ubuntu instead of Intel Graphics, but I have two screens: my laptop screen and a external monitor (HDMI).
If I uninstall the nvidia drivers, the external monitor works again (because Intel is being used).
When I install the drivers to use the nvidia card, the external monitor doesn't work. Nvidia X Server Settings doesn't recognize it and neither Ubuntu settings. If I set Intel Graphics on Nvidia X Server Settings, the external monitor doesn't work too. The only way it works is if I uninstall the driver completely.
I'm using the 367.57 driver.
xrandr output
Screen 0: minimum 8 x 8, current 1366 x 768, maximum 16384 x 16384
LVDS-1-1 connected primary 1366x768+0+0 344mm x 194mm
1366x768 60.06*+
1360x768 59.80 59.96
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
960x600 60.00
960x540 59.99
800x600 60.00 60.32 56.25
840x525 60.01 59.88
800x512 60.17
700x525 59.98
640x512 60.02
720x450 59.89
640x480 60.00 59.94
680x384 59.80 59.96
576x432 60.06
512x384 60.00
400x300 60.32 56.34
320x240 60.05
VGA-1-1 disconnected
HDMI-1-1 disconnected
DP-1-1 disconnected
lspci | grep VGA output
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
01:00.0 VGA compatible controller: NVIDIA Corporation GF108M [GeForce GT 540M] (rev a1)
xorg.conf
Section "ServerLayout"
Identifier "layout"
Screen 0 "nvidia"
Inactive "intel"
EndSection
Section "Device"
Option "Coolbits" "28"
Identifier "intel"
Driver "modesetting"
BusID "PCI:0@0:2:0"
Option "AccelMethod" "None"
EndSection
Section "Screen"
Identifier "intel"
Device "intel"
EndSection
Section "Device"
Identifier "nvidia"
Driver "nvidia"
BusID "PCI:1@0:0:0"
Option "ConstrainCursor" "off"
EndSection
Section "Screen"
Identifier "nvidia"
Device "nvidia"
Option "AllowEmptyInitialConfiguration" "on"
Option "CoolBits" "31"
Option "RegistryDwords" "PowerMizerEnable=0x1; PerfLevelSrc=0x2222; PowerMizerDefault=0x2; PowerMizerDefaultAC=0x2"
Option "OnDemandVBlankInterrupts" "true"
EndSection
The line Option "RegistryDwords" "PowerMizerEnable=0x1; PerfLevelSrc=0x2222; PowerMizerDefault=0x2; PowerMizerDefaultAC=0x2" is needed because my GPU needs to be underclocked to work properly. Works fine on my laptop screen, I believe it's not the problem. If I remove the line, the screen freezes 10 seconds after login.
I have tried to
- Reinstall nvidia drivers
- Reconnect HDMI (like a thousand times)
- All the answers to this Dual monitor not working - Intel Graphics & Nvidia 960m
