I've just done a fresh install of Ubuntu 13.10 on my Asus K53SV but I noticed that the cursor is flickering a lot and some times disappear. I never had this issue before with other Ubuntu release. What can I do?
System Settings > Screen Display. There is an unknown monitor. Disable it, it should be good
Haseen
  • 101
You could try disabling the gnome-settings-daemon cursor plugin, then doing a restart or log out/in
To do so run this in a terminal
gsettings set org.gnome.settings-daemon.plugins.cursor active false
If desiring to reactivate then just rerun the command but use true instead of false
doug
  • 17,212
I had the same problem with my Asus K53SM.I tried to disable unknown display(if it exists), which is located in System Settings > Hardware > Displays.
guntbert
  • 13,475
