What is the difference between the commands adduser and useradd on Ubuntu?
useraddis native binary compiled with the system. But,adduseris a perl script which usesuseraddbinary in back-end.
adduseris more user friendly and interactive than its back-enduseradd. There's no difference in features provided.also
adduseris a wrapper foruseradd.
Source: What's the difference between “adduser” and “useradd”?
- 174,089
- 51
- 332
- 407
Always use adduser (and deluser when deleting users) when you're creating new users from the command line. (If you're writing a script, especially if you aim for portability, you might want to use the lowlevel utilities instead – and adduser/deluser might not be available on all distros, e.g. on SuSE.)
The useradd, userdel and usermod commands are lowlevel utilities which are there for historical reasons, while adduser/deluser Do The Right Thing™. (I remember which to use by thinking that user* comes after adduser/deluser in the alphabet, and therefore is "worse".)
According to the respective manpages (on Ubuntu 12.04 Precise Pangolin, i.e. a Debian derivative system).
Manpage for adduser says:
(Emphasis added.)
adduserandaddgroupadd users and groups to the system according to command line options and configuration information in/etc/adduser.conf. They are friendlier front ends to the low level tools likeuseradd,groupaddandusermodprograms, by default choosing Debian policy conformant UID and GID values, creating a home directory with skeletal configuration, running a custom script, and other features.adduserandaddgroupcan be run in one of five modes:
Manpage for useradd says:
useraddis a low level utility for adding users. On Debian, administrators should usually useadduser(8)instead.
See also: What's the difference between “adduser” and “useradd”? (on SuperUser)
Another couple of differences, that lead to specific scenarios where useradd might be preferable.
In some newer distros, including Ubuntu 14.4, adduser will prompt for information such as password and "gecos" (data for the finger command). This means it can be less suitable for calling from a script (credit: already mentioned in a comment by Wernight).
The prompts can be suppressed by passing null arguments:
adduser --disabled-password --gecos "" USERuseraddallows you to pass multiple additional groups to add a user to by means of the-Goption.adduserseems to require that you call the command once for each group to add.
adduser is friendlier in that it sets up the account's home folders and other settings (e.g. automatically loading system stats and notifications on login), whereas useradd just creates the user.
- 4,606
Basic difference is "adduser" will create home directory & add skeleton files to that directory where "useradd" wont create any home directory & skeleton files !
adduser try :
Adding user `try' ...
Adding new group `try' (1001) ...
Adding new user `try' (1001) with group `try' ...
Creating home directory `/home/try' ...
Copying files from `/etc/skel' ...
Enter new UNIX password:
Retype new UNIX password:
passwd: password updated successfully
Changing the user information for try
Enter the new value, or press ENTER for the default
Full Name []:
Room Number []:
Work Phone []:
Home Phone []:
Other []:
Is the information correct? [Y/n] y
useradd try1 :
# ll /home/
total 20
drwxr-xr-x 5 root root 4096 Oct 26 15:52 ./
drwxr-xr-x 22 root root 4096 Oct 26 15:47 ../
drwx------ 8 ashishk ashishk 4096 Oct 26 15:50 ashishk/
drwxr-xr-x 3 root root 4096 Oct 14 13:02 .ecryptfs/
drwxr-xr-x 2 try try 4096 Oct 26 15:52 try/
root@chef-workstation:/home/ashishk#
- 2,557
- 3
- 20
- 24
The biggest different between using adduser and useradd is:
- With
addusercommand, the home folder for the user will be created as default. - With
useraddcommand, there is no home folder for the user.
So I suggest you to use adduser instead of using useradd.
- 119,640
- 121
I'll also point out that adduser does not always have the -M option and also does not respect the --system flag which specifically says:
Note that useradd will not create a home directory for such an user, regardless of the default setting in /etc/login.defs (CREATE_HOME). You have to specify the -m options if you want a home directory for a system account to be created.
If you're trying to create a system user without a home directory then use useradd --system -M.
- 263
The adduser interactive way to creates accounts and pwd with single command. Which can be only found in the Debian family distros.
Both adduser & useradd do the same functionality; with few differences in favour of adduser.
When creating a user with adduser it will automatically encrypt the user home directory ( with permission of 755 ).
- 11
Specifically, with useradd you should be more explicit as it doesn't e.g. create a home directory,you should use the -m option or the -p to set a password. Also another main difference is that useradd has different settings from adduser e.g. set a different shell for the user. In most distros useradd sets usr/bin/sh while adduser sets usr/bin/bash
