Is there a way to deny Firefox access to files in the home directory? Every time an ADSL modem light is blinking suspiciously, I am worried about my files being transferred to a hacker.
Revised, incorporating Dmytro's insight regarding the necessary xhost commands, better use of sudo making this much simpler, & equiping /home/foxy/ with the necessary files. Works for me on 16.04 with plain Openbox (like a leaner Lubuntu).
Yes, you could do that. Create another user account, we'll call it "foxy", either with something like System Settings, or from a command line:
sudo adduser foxy
Now you need to provide that user with the config files needed to use Firefox. You can probably do that most properly by relogging as foxy and doing it from there, but I found it was sufficient to copy the "hidden" "dot files", like .config and .mozilla from my home directory into /home/foxy/ & then:
chown -R foxy:foxy /home/foxy
At this point, since you shouldn't need to ever log in as foxy any more, it might be a good idea to reset foxy's password to some absurdly long and random string. Seriously long and random since you won't need to remember it. This is similar to the approach used by Ubuntu to semi-disable the root account. This isn't a real big deal since foxy isn't going to be in the sudoers file anyway, but as long as we're being seriously hard-ass 'noid, let's go all the way. Since you will need to enter it twice you'll want it in the clipboard or in an open terminal or editor to copy it from. But be careful not to write it to a drive. You could even make and mount a ramfs filesystem and write a text file to it, then open the text file and create your long random string in it and copy from there. For special high security purposes ramfs is superior to tmpfs because it never gets written to swap. (But be careful using it more generally because it will cheerfully use ALL your RAM if you keep putting things in it.) Anyway, to change foxy's password, use:
sudo passwd foxy
Now we make 2 tiny scripts. We'll call the first one ffx and put it in some directory on the path. Like this:
#!/bin/bash
# This file, ffx, needs to go in a directory on the path
sudo /path/to/a_password_exempted_directory/ffx_2.sh
(You could probably do that as a function or alias and load it with your bash profile or one of the similar files, instead of making it a script on your path, if you prefer, but I haven't tested that.)
The other we'll call ffx_2.sh and put in a directory that has been exempted from the requirement of typing a password with sudo with the appropriate lines in /etc/sudoers. Like this:
#!/bin/bash
# This needs to go in a directory that is exempted from password requirement in /etc/sudoers
# Allows foxy to access the logged in user's xserver
xhost nis:foxy@
# starts firefox as foxy with home set to /home/foxy
sudo -u foxy --set-home firefox
# Removes foxy's privilege to use the xserver
xhost -nis:foxy@
I'm following Dmytro's 'noid approach and turning on foxy's access to the x server only when using Firefox and turning it off afterwards. I don't think this is actually necessary. Maybe it is more secure, but that isn't obvious to me. I think you can actually just run the first xhost command:
xhost nis:foxy@
ONCE & then foxy's access will persist across reboots. If I'm right and you do it that way, you can take both the xhost commands out of the script, after running the first command once.
Either way, you can invoke this with ffx from a terminal, run box or manually edited menu like the Openbox menu or 9menu. You can make a desktop file for it and put it in /usr/share/applications and adaptive menus like the debian menu from the package menu or, I'm told, Launcher in Unity, should pick up on it.
To anticipate an objection, this is NOT a security risk like plain sudo firefox or gksudo firefox would be. Sudo and similar commands are fundamentally about doing something as some other user. But they are used to do something AS ROOT so often, they default to -u root (which you can also do explicitly) to save keystrokes. It is not using sudo with Firefox that is dangerous, it is using sudo to run Firefox AS ROOT that is dangerous. When you use the -u option and specify another ordinary user, you aren't running Firefox as root.
Comparison to the script-blocking approach:
cons:
more work to implement than noscript or librescript
less of a "standard" approach
script blockers CAN reduce resource usage, this doesn't
pros:
Firefox can access all functions of script dependent websites.
Doesn't require any tweaking after initial implementation.
Easier to use.
You can STILL use Firefox extensions to reduce resource usage. Noscript isn't the only option for that. Flashblock, FlashStopper, Gifblock, Image Block, etc.
- 610
As a simple and straightforward solution, you can install noscript Firefox extension.
By default it disables local file access. You can see it in noscript options → Advanced tab → ABE sub-tab → SYSTEM rules.
It also lets you globally control Javascript execution, and on a per domain basis. If you don't need these feature you can disable in the extension settings (but according to the point of view of your question, I think you will find it useful).
You can get more info at their website noscript.net.
