I need a command to list all users as well as commands to add, delete and modify users from terminal - any commands that could help in administrating user accounts easily by terminal.
To list
To list all local users you can use:
cut -d: -f1 /etc/passwd
To list all users capable of authenticating (in some way), including non-local, see this reply.
Some more useful user-management commands (also limited to local users):
To add
To add a new user you can use:
sudo adduser new_username
or:
sudo useradd new_username
See also: What is the difference between adduser and useradd?
To remove/delete
To remove/delete a user, first you can use:
sudo userdel username
Then you may want to delete the home directory for the deleted user account :
sudo rm -r /home/username
Please use with caution the above command!
To modify
To modify the username of a user:
usermod -l new_username old_username
To change the password for a user:
sudo passwd username
To change the shell for a user:
sudo chsh username
To change the details for a user (for example real name):
sudo chfn username
To add a user to the sudo group:
adduser username sudo
or
usermod -aG sudo username
And, of course, see also: man adduser, man useradd, man userdel... and so on.
- 17,371
- 174,089
- 51
- 332
- 407
The easiest way to get this kind of information is getent - see manpage for the getent command
. While that command gives the same output as cat /etc/passwd it is useful to remember because it will give you lists of several elements in the OS.
To get a list of all users you type (as users are listed in /etc/passwd)
getent passwd
To add a user newuser to the system you would type
sudo adduser newuser
to create a user that has all default settings applied.
Bonus: To add any user (for instance anyuser) to a group (for instance cdrom) type
sudo adduser anyuser cdrom
You delete a user (for instance obsolete) with
sudo deluser obsolete
If you want to delete his home directory/mails as well you type
sudo deluser --remove-home obsolete
And
sudo deluser --remove-all-files obsolete
will remove the user and all files owned by this user on the whole system.
- 13,475
This should get, under most normal situations, all normal (non-system, not weird, etc) users:
awk -F'[/:]' '{if ($3 >= 1000 && $3 != 65534) print $1}' /etc/passwd
This works by:
- reading in from
/etc/passwd - using
:as a delimiter - if the third field (the User ID number) is larger than 1000 and not 65534, the first field (the username of the user) is printed.
This is because on many linux systems, usernames above 1000 are reserved for unprivileged (you could say normal) users. Some info on this here:
A user ID (UID) is a unique positive integer assigned by a Unix-like operating system to each user. Each user is identified to the system by its UID, and user names are generally used only as an interface for humans.
UIDs are stored, along with their corresponding user names and other user-specific information, in the /etc/passwd file...
The third field contains the UID, and the fourth field contains the group ID (GID), which by default is equal to the UID for all ordinary users.
In the Linux kernels 2.4 and above, UIDs are unsigned 32-bit integers that can represent values from zero to 4,294,967,296. However, it is advisable to use values only up to 65,534 in order to maintain compatibility with systems using older kernels or filesystems that can only accommodate 16-bit UIDs.
The UID of 0 has a special role: it is always the root account (i.e., the omnipotent administrative user). Although the user name can be changed on this account and additional accounts can be created with the same UID, neither action is wise from a security point of view.
The UID 65534 is commonly reserved for nobody, a user with no system privileges, as opposed to an ordinary (i.e., non-privileged) user. This UID is often used for individuals accessing the system remotely via FTP (file transfer protocol) or HTTP (hypertext transfer protocol).
UIDs 1 through 99 are traditionally reserved for special system users (sometimes called pseudo-users), such as wheel, daemon, lp, operator, news, mail, etc. These users are administrators who do not need total root powers, but who perform some administrative tasks and thus need more privileges than those given to ordinary users.
Some Linux distributions (i.e., versions) begin UIDs for non-privileged users at 100. Others, such as Red Hat, begin them at 500, and still others, such Debian, start them at 1000. Because of the differences among distributions, manual intervention can be necessary if multiple distributions are used in a network in an organization.
Also, it can be convenient to reserve a block of UIDs for local users, such as 1000 through 9999, and another block for remote users (i.e., users elsewhere on the network), such as 10000 to 65534. The important thing is to decide on a scheme and adhere to it.
Among the advantages of this practice of reserving blocks of numbers for particular types of users is that it makes it more convenient to search through system logs for suspicious user activity.
Contrary to popular belief, it is not necessary that each entry in the UID field be unique. However, non-unique UIDs can cause security problems, and thus UIDs should be kept unique across the entire organization. Likewise, recycling of UIDs from former users should be avoided for as long as possible.
- 30,732
list of all users who can login (no system users like: bin,deamon,mail,sys, etc.)
awk -F':' '$2 ~ "\$" {print $1}' /etc/shadow
add new user
or
delete/remove username
If you want to delete the home directory (default the directory /home/username)
sudo deluser --remove-home username
or
sudo rm -r /path/to/user_home_dir
If you want to delete all files from the system from this user (not only is the home diretory)
To find out the users which have home-directories in the /home-folder on the machine, run the following commands
cd /home
ls
You can then see the users who have authorization to log into the server. If we want to look into the files of any users, you must be the root user.
- 123
- 1
Ok here is a trick that will help you sort this. The terminal has auto completion if you type user and hit Tab key twice it will list all the commands that exist with user as the first 4 chars.
user (tab tab)
gives me as possible options
useradd userdel usermod users users-admin
if you want to know more about a command google it or type man
man useradd
gives
useradd - create a new user or update default new user information
to list users you should go with what Mitch said.
Hope that helps I love tab completion in bash saves me from remembering things.
- 119
lslogins
lslogins (1) - display information about known users in the system
lslogins is a Linux command that displays information about known users on a system. It gathers information from various sources such as /etc/passwd, /etc/group, and other system-specific user information databases. The command scans the wtmp and btmp logs, the /etc/shadow (if necessary) and /etc/passwd files, and outputs the desired data. The optional username parameter can be used to output information only for the specified user.
- 17,371
The first answer recommends:
But using this and counting number of users you get:
$ cut -d: -f1 /etc/passwd | wc -l
46
46 users for a laptop computer are a lot!. So use this instead:
$ cat /etc/passwd | grep -vE '(/bin/false|/sbin/nologin|/bin/sync)' | cut -d: -f1
root
rick
guest-atkb2q
guest-u4sf2i
guest-rmlbtg
guest-mz53vp
To remove guest accounts (who don't have saved files anyway) use:
$ cat /etc/passwd | grep -vE '(/bin/false|/sbin/nologin|/bin/sync|guest-)' | cut -d: -f1
root
rick
Some sample users removed from the listing are:
systemd-timesync:x:100:102:systemd Time Synchronization,,,:/run/systemd:/bin/false
gnats:x:41:41:Gnats Bug-Reporting System (admin):/var/lib/gnats:/usr/sbin/nologin
sync:x:4:65534:sync:/bin:/bin/sync
guest-atkb2q:x:999:999:Guest:/tmp/guest-atkb2q:/bin/bash
It turns out most of the users on a single user system are actually programs that have set themselves up as users.
- 105,762
