58
I know that I can enable IP forward by echoing 1 to /proc/sys/net/ipv4/ip_forward, but how can I make this permanent?
By the way I want another method rather than start up scripts, is there any?
Eric Carvalho
  • 55,453
Hojat Taheri
  • 5,539
Edit /etc/sysctl.conf and search for the following lines:
# Uncomment the next line to enable packet forwarding for IPv4
#net.ipv4.ip_forward=1
Uncomment net.ipv4.ip_forward=1:
Or in one line command :
sudo sysctl -w net.ipv4.ip_forward=1
boly38
  • 223
Eric Carvalho
  • 55,453
26
Permanent setting using /etc/sysctl.conf
If we want to make this configuration permanent the best way to do it is using the file /etc/sysctl.conf where we can add a line containing net.ipv4.ip_forward = 1
/etc/sysctl.conf:
If you already have an entry net.ipv4.ip_forward with the value 0 you can change that to 1.
To enable the changes made in sysctl.conf you will need to run the command:
sudo sysctl -p /etc/sysctl.conf
On RedHat based systems this is also enabled when restarting the network service:
service network restart
and on Debian/Ubuntu systems this can be also done restarting the procps service:
sudo /etc/init.d/procps restart
Source: How to Enable IP Forwarding in Linux
guntbert
  • 13,475
Meintjes
  • 2,450
If you need to enable it in script you can use commands below to enable
sed -i 's/#net.ipv4.ip_forward=1/net.ipv4.ip_forward=1/' /etc/sysctl.conf
sysctl -p
or disable:
sed -i 's/net.ipv4.ip_forward=1/net.ipv4.ip_forward=0/' /etc/sysctl.conf
sysctl -p
ilya
  • 59
