I've done a fresh install of Ubuntu 16.04
When i connect another computer or Gigabit switch through the wired connection it fails to assign an ip address to enp5s0.
I understand i could configure a static ip but i would prefer to resolve this issue.
Thanks for all your help, however i've made the following progress.
I ran this command to check the model number of my Ethernet Controller
lspci | grep Realtek
The output
05:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller (rev 05)
I then checked checked what driver the kernel was loading
lsmod | grep r816*
The output
r8169 81920 0
mii 16384 1 r8169
Seeing that they did not match i headed over to the Realtek website to get the RTL8101 Driver but they only have it for the 3.x, 2.6.x and 2.4.x kernels.
And so either I have to wait until Realtek release a driver for kernel 4.x or upgrade my hardware.
spacelander thanks for the link i learned from it
heynnema i assure you that you can connect direct and get an ip number, as I've been doing it for years and I'm sure with the correct driver I'll do it again.
Thanks & Regards Jonny
