I have been trawling these questions and trying many different solutions to get this working, but I seem to have a problem with getting my routing set up correctly. I have a box installed in a network with no Internet access with the exception of OpenVPN to my server. Everything else is blocked leaving the LAN segment the box is on.
The box opens a connection to my VPN server, so now I have p2p1 and tun0. The setup for /etc/network/interfaces is:
# The loopback network interface
auto lo
iface lo inet loopback
# The primary network interface
auto eth0
iface eth0 inet static
    address 192.168.56.211
    netmask 255.255.255.0
    gateway 192.168.56.251
    dns-nameservers 192.168.100.20 192.168.50.35
The OpenVPN connection comes up and connects as you would expect, allowing me to SSH into the box via the VPN from outside the LAN. The issue is that all outgoing data is trying to use the local gateway. I haven't been able to get any routing configuration so far to pass the following:
  1. Local LAN via 192.168.56.251
  2. Secondary LAN (192.168.50.x) via 192.168.56.251
  3. VPN Server via 192.168.56.251
  4. Internet via tun0 (OpenVPN interface)
I've tried using
up route add -net 1.2.3.4/32 gw 10.8.4.9
to configure at least one server to get a connection via the VPN, but still no joy. It's like nothing is routing correctly. At the very minimum I at least need to get apt-get working via the VPN and then getting my webserver to go via it as well. I an cope with it being limited like that, but ideally I just want to fix it so the routes are correct!
teknetia
In my case, eth1 is the device I want to be an available gateway on my LAN, and ppp0 is the name of my VPN connection when it's active on that machine (connects via eth0 but for deadswitch security we won't name it in the routing).
Setup your IPtables for NAT from the LAN to the VPN-connected gateway:
iptables -t nat -A POSTROUTING -o ppp0 -j MASQUERADE
iptables -A FORWARD -i ppp0 -o eth1 -m state --state RELATED,ESTABLISHED -j ACCEPT
iptables -A FORWARD -i eth1 -o ppp0 -j ACCEPT
Remember to save your iptables and activate IP forwarding.
