Trying to run Game Dev Tycoon on Ubuntu 64. It asks for the above object.
I ran sudo apt-get install libudev1:i386 and it came back already installed.
I have /lib/i386-linux-gnu/libudev.so.1 but no libudev.so.0 anywhere.
To fix, I linked libudev.so.1 to libudev.so.0:
sudo ln -sf /lib/$(arch)-linux-gnu/libudev.so.1 /lib/$(arch)-linux-gnu/libudev.so.0
The easiest method I found was to just download the .deb (direct link to 64-bit download and to 32-bit download) and double click it to install it or use dpkg to install it:
dpkg -i libudev0_175-0ubuntu9_amd64.deb
In previous version of ubuntu this package was available in the official repositories. You can install with the following:
sudo apt-get install libudev0:i386
I had the same problem for a different program, but Sean's accepted answer didn't help me at all. On my upgraded install of 64-bit 13.04, libudev0 is not available either in 64-bit form or i386 form. And ia32-libs is already installed. So no dice.
What I had to do was a slightly modified version senshikaze's more technical solution. I manually symlinked libudev.so.0 to libudev.so.1 in the x86_64 lib directory, thusly:
cd /lib/x86_64-linux-gnu/
sudo ln -sf libudev.so.1 libudev.so.0
This fixed it for me.
For 64-bit Ubuntu, it is in the 32-bit libudev0 package.
You can install that with the following command:
This package was removed from Ubuntu in 14.04. You will need to install it from an older version.
This error might happen when trying to use nw executable from Node Webkit. Like this:
./nw: error while loading shared libraries: libudev.so.0: cannot open shared object file: No such file or directory
Get hex editor that allows you to change ASCII string of binary, eg. hexedit:
sudo apt-get install hexedit.cd ~/Dokumenty/node-webkit-*.sudo:
sudo hexedit nw.libudev.so.0 as ASCII string:
libudev.so.0.0 in libudev.so.0 string to 1, so it becomes: libudev.so.1:
0 in libudev.so.0 string.You're done. This also fixes problem with Atraci binary when following same instructions except hex editing Atraci file instead of nw.
The only answer here that works on Ubuntu 14.04 is the accepted answer, and since many comments point out that this can cause issues with the system down the road (although I don't know about that myself) I came up with a compromise. This script will prompt (in the terminal) for your root password. It will create the symbolic link and launch the application (in my case, popcorn time). When you quit the application, it will use the existing sudo session to remove the symbolic link:
#!/bin/sh
sudo ln -sf /lib/i386-linux-gnu/libudev.so.1 /lib/i386-linux-gnu/libudev.so.0
./Popcorn-Time #replace this line with the path to the executable you want to launch
sudo rm /lib/i386-linux-gnu/libudev.so.0
I just found a way to make this work, is pretty silly though.
I have Google Chrome installed on my system and Chrome has this shared object embedded. So, I just had to make a symbolic link to the library on Chrome installation directory.
ln -sf /opt/google/chrome/libudev.so.0 /lib/x86_64-linux-gnu/libudev.so.0
It works pretty fine for me.
This was simplest solution I found
sudo ln -s /lib/x86_64-linux-gnu/libudev.so.1 /lib/x86_64-linux-gnu/libudev.so.0
as Phil Strong pointed out
install libudev.so.1
then link it as libudev.so.0
sudo ln -sf /lib/x86_64-linux-gnu/libudev.so.1 /lib/x86_64-linux-gnu/libudev.so.0
i did this on 14.04, but should be similar. just delete the package and re-install. the correct libraries are installed appropriately.
apt-get purge google-chrome-stable
apt-get install google-chrome-stable
i'm sure the other answers work, but i have a basic beef in modifying file system objects that are managed by configuration management packages.
This is what I used to solve the same problem on 32 bit Ubuntu 15.04.
cd i386-linux-gnu
UPDATE I made a bash script to wrap around the program you want to execute. You can add it to your local bin folder and just start the program without the copy & pasting or running shell scripts.
#!/bin/bash
ProgramToExecute="/PATH/TO/PROGRAM" #Example: $HOME/dart/./DartEditor
system=$(uname -m) #Returns x86_64 on 64 bit systems
libdir="/lib/$system-linux-gnu"
libudev1="$libdir/libudev.so.1"
if [ ! -f $libudev1 ]
then
#check if an i386 folder exist because ' uname -m' returns i686 instead of i386.
libdir="/lib/i386-linux-gnu"
#if none of the lookups return a file, this script exits,
BreakUpNotice="This $libudev1 isn't working out. It's not you
it's me. Or maybe you forgot to install libudev1 library.
sudo apt-get install libudev1 "
[ ! -f $libudev1 ] && echo $BreakUpNotice && exit 0
fi
libudev0="$libdir/libudev.so.0"
echo "$libudev1 found."
sudo ln -sf $libudev1 $libudev0
sudo -k #revoke sudo
$($ProgramToExecute)
NoticeAfterExec="Enter sudo to del libudev link (recommended) or press CTRL+C to cancel."
RmSuccess="And $libudev0 link is gone."
RmFailed="Whaat? $libudev0 still exists."
echo $NoticeAfterExec
sudo rm $libudev0
sudo -k
[ ! -f "$libudev0" ] && echo $RmSuccess || echo $RmFailed
exit
OLD ANSWER In Ubuntu 14.04 I was getting the error message from the Dart Editor when trying to use Live Preview (Chromium). The error was solved by installing libudev1 and creating a symbolic link.
I also used the script mentioned above by TenLeftFingers to execute DartEditor.
#!/bin/sh
./DartEditor
If the Dart Editor doesn't execute make sure JAVA is installed and that is not a permission issue.
sudo apt-get install python-software-properties
sudo add-apt-repository ppa:webupd8team/java
sudo apt-get update
sudo apt-get install oracle-java7-installer
and make the IDE executable:
sudo chmod a+x ./DartEditor
This worked for me.
I was getting the same error on my 32-bit system after upgrading from Xubuntu Precise to Trusty. This fixed it for me:
sudo dpkg-reconfigure google-chrome-stable
I found it here. With absolutely no parameters, I'm not quite sure how this fixed it, but it did. What I liked best is that it didn't require doing anything that would potentially cause problems for me in the future, and didn't require me hunting down any packages.
If anyone stumble upon this page while digging the web for fixes on the libudev.so.0 & the Emotiv Epoc SDK Dev Edition on Ubuntu, I hope the following will help:
// my config is 64bit Ubuntu 13.04
sudo ln -sf /lib/x86_64-linux-gnu/libudev.so.1. /lib/x86_64-linux-gnu/libudev.so.1
sudo ln -sf /lib/x86_64-linux-gnu/libudev.so.1 /usr/lib/libudev.so.0
sudo ln -sf /lib/i386-linux-gnu/libudev.so.1. /lib/i386-linux-gnu/libudev.so.1
sudo ln -sf /lib/i386-linux-gnu/libudev.so.1 /usr/lib/libudev.so.0
The EmotivControlPanel, EmoKey, EmoComposer, the Java examples & little customized Qt examples should be able tu run after doing the above ( I already tried all the steps above + others found on the web ( stack overflow, .. ), but none were working for me, so that's what I ended up doing after some "try & errors"
Last but not least, If anyone here knows how to run programs compiled against 32bit libs on a 64bit system WHILE SPECIFYING TO USE A PROVIDED 3RD PARTY 32BIT LIBRARY ?
more precisely, for those who knows what I'm talking about, how am I supposed to run the "EmoCube" & "BlueAvatar" Qt examples on my 64bit system ?
--> for what I've tried so far, the most I could get was: "error while loading shared libraries: libedk.so.1: wrong ELF class: ELFCLASS64"
I guess that a symlink to that lib in the i386 directory wouldn't make it ( although I did not try it yet ), so if anyone has an answer ... I.m looking forward to reading it.
Cheers all +
Run these commands in a terminal:
sudo cp libudev.so.0.13.0 libudev.so.1
This has helped me
