I got this error while booting
'mount: error while loading shared libraries: libudev.so.0 : no such file or directory'
Then i followed this
I Booted into recovery mode and opened terminal and installed libudev0 using
apt-get install libudev0
It says its already installed
Even i linked libudev0 and libudev1 as mentioned here But no gain :(
EDIT: Output of locate -e libudev.so.0
/lib/i386-linux-gnu/libudev.so.0
/lib/i386-linux-gnu/libudev.so.0.13.0
/lib/x86_64-linux-gnu/libudev.so.0.13.0
I am guessing that you are running a 64bit system. If so, this dirty hack should work:
sudo ln -s /lib/x86_64-linux-gnu/libudev.so.0.13.0 /lib/x86_64-linux-gnu/libudev.so.0
That will crate a link named libudev.so.0 that points to /lib/x86_64-linux-gnu/libudev.so.0.13.0.
terdon
  • 104,119
i had the same problem on ubuntu 12.04 x64, solved it fast first remounting with
sudo mount -o remount, rw /
then locating the libudev.so.0
then doin the "dirty trick"
worked perfectly to me, thanx Terdon!
muru
  • 207,228
