12
I have installed Ubuntu 13.04 in a new partition and I have some issues with bluetooth.
I usually use bluetooth to connect to my wireless headset, in the old partition with Ubuntu 12.10 everything is okay.
Ubuntu is able to detect my bluetooth receivers but I can't pair my device. After googling I found that all I need is to add Enable=Socket in the general section of /etc/bluetooth/audio.conf.
After restarting the bluetooth daemon I am able to pair my wireless A2DP receiver and I see the bluetooth adapter under the audio setting, that means that pulseaudio has recognized my A2DP adapter.
Unfortunately when I play the audio file, I hear the output through the PC speakers rather that my bluetooth handcuffs.
Any idea how to resolve this?
I tried formatting and reinstalling Ubuntu 64-bit from scratch in order to get a clean install but the problem is still there. I suspect the Ubuntu team has changed something in the bluetooth settings from 12.10 to 13.04.
Aditya
  • 13,616
5 Answers5
This worked for me:
1) Open /etc/bluetooth/audio.conf with the following command*:
gksudo gedit /etc/bluetooth/audio.conf
(*) The command line above requires gedit and gksu packages.
2) find "Enable =..." under [General] section and delete Socket from the list.
[General]
Enable = ....
3) Add this line in General section:
Disable = Socket
4) Save, and close gedit
5) Restart the bluetooth service with the following command:
sudo service bluetooth restart
6) Restart pulseaudio for good measure.
pulseaudio -k
pulseaudio -D
7) Cross Your Fingers and try.
I'm running ubuntu 13.04 and had a similar issue after upgrading from 12.10, I've managed to temporarily get around it, but unfortunately this needs to be redone after each reboot. If anybody can automate this process please let me know how. Thanks.
First we need to kill pulseaudio, -- but pulseaudio always restarts, so we need to disable that - Into terminal;
sudo gedit /etc/pulse/client.conf
change autospawn = yes to autospawn = no, and set daemon-binary to /bin/true. Make sure these lines are uncommented. Save, and close the file. Done, pulse audio will no longer restart after a crash or force close.
Next run,
and under General add
Enable=Socket
close and save the file. Run in terminal;
run in terminal;
pulseaudio --kill
now connect to the bluetooth device (I've tested this using BLUEMAN). Run in terminal;
pulseaudio
then in a different terminal window;
remove Socket, leaving Enable=. Save and close the file and run in terminal;
connect to your bluetooth device again; - and it should (hopefully) work.
user165648
  • 31
I had almost exactly the same problem as original post. I tried about every suggestion I could find. After days of trial and error my Bose AE2w finally connects and stays connected in A2DP profile.
First, I mute my sound card in sound options before I connect to my bluetooth heaset (this step may be unnecessary, but it is what I do). And I have edited /etc/bluetooth/audio.config with these settings (comments deleted in example)
[General]
Enable=Gateway,Source
Disable=Socket
AutoConnect=false #test later with true
[Headset]
MaxConnected=1
[A2DP]
SBCSources=1
MPEG12Sources=0
Then click connect in bluetooth options (if it isn't automatic). Last, select the A2DP profile in Sound options. I honestly don't know what some of the setting do, but it has been working for me for 2 days.
I don't know for sure, but I think the root of the problem is that the "Sound" window only lists 1 device (but the device 2 profiles). Because on windows 7/8 in the sound options it lists 2 devices (one for each profile), making it possible to select a "default device [profile]".
Thanks guys, I wouldn't have solved this problem on my own, I hope this helps someone.
edit: this has been working for a week on trusty tahr amd x64 with creative x-fi platinum, bose ae2w, soundbot bluetooth adapter.
Corey
  • 41
I had the same problems after upgrading from 12.10. After removing all configuration files from my home directory and reinstalling from scratch bluetooth ad2p was working again. Not the most ideal solution, but it worked.
MarkMe
I had the same problem. My problem was, that avahidaemon crashed.
  1. sudo service avahi-daemon start #start avahi
  2. sudo service bluetooth restart #restart bluetooth to connect to avahi again
  3. sudo pactl list cards short #get name auf bluetooth-card
  4. sudo pactl set-card-profile <> a2dp #For me sudo pactl set-card-profile bluez_card.00_1E_7C_01_6D_45 a2dp
Hope this helps.
regards Anton
