I have a Sennheiser MM100 bluetooth stereo headset (using A2DP) I'd like to use on my Lubuntu machine. The headset works fine with my phone.
Please note that unlike all other Ubuntu flavours, Lubuntu does not come with Pulseaudio.
It is detected by Lubuntu's Blueman Bluetooth configuration application and I can establish a connection successfully. It also appears to actually communicate as it shows data being sent back and forth. However, Sound keeps coming out of the loudspeakers only, while the headset remains silent. I would have expected the sound to come from my headset at this point.
Where do I start troubleshooting here?
Note about the answer here - It appears that Lubuntu comes without Pulseaudio and I assumed Pulse is needed for A2DP to work and that OP would have installed it. It appears not to be the case. The answer below is about a Pulseaudio installation.
Make sure you've selected the right output sink for the application you're expecting sound from.
Similar to my answer in a similar question, start by installing and starting pavucontrol and check:
  • In the Output Devices tab
    • Check the presence of your Bluetooth device. I assume it's listed there stating you see it in another application.
    • Check the obvious settings for that entry.
  • In the Configuration tab
    • Check the audio profile. Make sure you've selected A2DP rather than 'headset' or 'off' (unless you want to, really).
  • In the Playback tab the application producing sound should be listed.
    • Try to see what output sink is selected and verify it is using your Bluetooth connection.
    • Check the output volume and mute status of this particular audio stream.
gertvdijk
  • 69,427
EDIT: So I finally got this working: 1) To make Pulse Audio support A2DP, this package needs to be installed: pulseaudio-module-bluetooth. But after that it's still not easy to make it work:
2) Gnome Bluetooth applet vs. Blueman: - I have not been able to make this work reliably with Blueman, but I found that it does with GNOME BLUETOOTH APPLET. I came across this solution when I decided to use Gnome Shell (3.4 at first) on my Lubuntu, which of course came with the Gnome Bluetooth applet (package name: gnome-bluetooth: If you decide to install it without the Gnome Shell, note that it will pull some gnome libraries it needs to work). - I removed the troublesome Blueman and paired the devices via the Gnome applet, which led to successfully streaming A2DP, Pulseaudio via Bluetooth. For this to work, BLUEMAN HAS TO BE REMOVED, else it will take control of managing all bluetooth connections. When I upgraded my Lubuntu installation from 12.04 to 13.04, Blueman was reinstalled and did just that, and things started working again after I removed it.
3) After installing it (I did via Synaptic) I restarted PA
pulseaudio --kill
pulseaudio --start
but that may be unnecessary, try it in case you experience problems at first.
4) To make the connection with the Sennheiser headset, I need to put it in PAIRING MODE by turning it on and holding down the on/off button for a bit longer, till the LED flashes red and blue (as opposed to connection mode - rapid blue flashing - that would usually suffice for connecting the headset to a host device that already knows it: that doesn't work). Then, in Gnome applet (it should remember the headset after first pairing), click the "connect" button for the Sennheiser M100 .
5) You may have to go into Audio Settings and select the M100 as output device, but I get audio through the headset and not the speakers even if the system soundcard is still selected.
Hope this works for you, too, but still: When you buy bluetooth hardware for use with your Ubuntu (or derivative) system, try and find something with explicit Linux support, preferably open drivers!
I made it work the following way :
Before going further :
  • Update your system (I'm running 13.10)
  • Remove blueman
  • Install pulseaudio-module-bluetooth, pavucontrol (Utility to set up pulseaudio) and make sure bluez is installed
  • Remove any "Disable=Socket" or "Enable=Socket" entry in file /etc/bluetooth/audio.conf (edit with sudo)
Steps :
  1. Put device in pairing mode (even if already paired)
  2. Pair the device with your system using default bluetooth manager (blueman should have been removed) or if already paired go to step 3
  3. Select A2DP or Audio Sink connection for the paired device. If it fails try "sudo hciconfig hci0 reset" (where hci0 is your bluetooth device) check scan is ok with hcitool scan then retry this step (do hciconfig -piscan to identify your bluetooth device)
  4. With pavutools, select a2dp in "configuration" tab and your device in "Playback" tab / If a2dp is not selected, try "pactl list cards short" to get your device id (1,2,3..) then do "pactl set-card-profile X a2dp" where X is your device id
  5. If it fails, restart avahi-daemon / bluetooth service and reset device through hciconfig hci0 reset. Check if scan is ok with hcitool scan. Then do steps 3 and 4
yilmi
  • 1,282
I had the same problem on Lubuntu 14.04.
In fact I had troubles on my Ubuntu 14.04 and XFCE and there decided to surrender to GNOME again. The GNOME bluetooth manager I also find more stable and user friendly then the description given below. But the lightness of Lubuntu is also due to the amazing job they did with LXDE, and there I didn't dare clogging the system with another (non native) desktop manager.
Here is what I found to fix the problem. My answer is mainly derived from this fix for mint
  1. install pulseaudio and a couple of extra components:
    sudo apt-get install pulseaudio pulseaudio-module-bluetooth bluez
  2. sudo gedit /etc/bluetooth/audio.conf and uncomment the following lines
     HFP=false
     [A2DP]
     SBCSource=1
     MPEG12Source=0
  3. pactl load-module module-bluetooth-discover
Done.
As other suggested, you might indeed want to install pavucontrol to select the A2DP output easily. It also helps managing audio in a more natural way than alsa with the primitive alsa mixer.
Andrea Borga
  • 1,100
