I've recently switched to Ubuntu, and the one thing that has been bothering me is the scroll speed, which I can't seem to change. In windows I used to have it set around 7 lines, but it seem to be around 3 on Ubuntu, and unchangeable. How can I change the speed?
If it's only for web, you can change the scroll speed in FireFox:
Editmenu >Preferences>Advancedtab >Browsinggroup: disable smooth scrolling
Fine-tuning:
- Type enter
about:configin the address bar - Find and change
mousewheel.withnokey.sysnumlinesto FALSE Then change the
mousewheel.withnokey.numlinesfrom 1 to whatever you want.For Firefox versions 73.3.1 and later: - change the
mousewheel.min_line_scroll_amountfrom 1 to whatever you want.
And a more general, system-wide solution:
For touchpads, some drivers allow customizing scroll sensitivity, like GPointingDeviceSettings (GSynaptics successor).
For mice, currently Gnome offers no way for a user to adjust a mouse wheel speed. It's a known wanted feature, triaged as WishList. A solution would be to use some hacks, or really dig deep into a mess of configuration files, and possibly some recompiles. Not fun if you need to adjust the value until you find a comfortable one.
- 20,055
- 57
- 82
- 84
- 20,726
Just unplug the mouse (mine was wireless), and then plug it back in to fix this issue.
I was searching for a long time for this fix and even rebooted the machine to no avail.
Maybe a full shutdown would have fixed the issue.
- 697
- 425
For Ubuntu 12.10 I found that it it a little different for the Firefox work around.
Open about:config (type it into the address bar) and search for:
Then change the number associated with it. Mine was set to 5. I changed it to 60 and it works how I want it now.
- 119,640
- 231
This tutorial worked for me:
- Open a terminal and run:
sudo apt-get install imwheel gedit ~/.imwheelrcPaste this, save, and close gedit:
".*" None, Up, Button4, 3 None, Down, Button5, 3 Control_L, Up, Control_L|Button4 Control_L, Down, Control_L|Button5 Shift_L, Up, Shift_L|Button4 Shift_L, Down, Shift_L|Button5imwheel --kill --buttons "4 5"Add the previous line to
~/.bashrcor your session autostart manager.
- 631
In Firefox 19, run about:config in the address bar, then modify the parameter mousewheel.min_line_scroll_amount to something higher (50). You don't have to restart FF.
- 440
I have Firefox 42.0 here, and I use a touchpad to scroll.
I found if I wanted to adjust the distance scrolled, I could change:
mousewheel.default.delta_multiplier_y
in about:config. Its default value was 100. A larger value would scroll further/faster.
- 2,009
Chromium Wheel Smooth Scroller
In Chrome, this is The Soluttion: https://chrome.google.com/webstore/detail/chromium-wheel-smooth-scr/khpcanbeojalbkpgpmjpdkjnkfcgfkhb
Just brilliant!
- 508
If you use two fingers on a touchpad to scroll, you can use synclient to adjust the sensitivity for the whole system.
If you don't have it installed:
sudo apt-get install xserver-xorg-input-synaptics
To see the current sensitivity threshold, check the output of:
synclient -l | grep ScrollDelta
To make it more sensitive, reduce the value:
synclient VertScrollDelta=33
This means you need to move your finger less to send each scroll event.
If you want to reverse the scroll direction, like Mac OS X's "natural scrolling", set a negative value.
But note that this will not let you configure the minimum distance scrolled when you move your fingers only a little bit. That must be configured per-app (or possibly per-desktop environment).
- 2,009
For those, who prefer to fix it Linux Desktop Way.
Wrote exhaustive instruction on how to add Scroll Ratio through libinput sources:
https://github.com/up-to-you/linux_notes/blob/master/mouse/scroll_speed.md
For those, who hates github (gitlab funs?), duplicated here (works for any mouse):
find libinput files
sudo updatedb
ll $(locate -A libinput.so)
most likely Canonical delivers their libinput libs with snaps
sudo snap list
sudo snap remove gnome-3-28-1804
check, that libinput lefts only in system folder, like :
/usr/lib/x86_64-linux-gnu/libinput.so
/usr/lib/x86_64-linux-gnu/libinput.so.10
/usr/lib/x86_64-linux-gnu/libinput.so.10.13.0
clone libinput source
git clone https://gitlab.freedesktop.org/libinput/libinput
cd libinput
modify src/evdev.c. Find evdev_read_wheel_click_props function and init angles.y = 361;
static inline struct wheel_angle
evdev_read_wheel_click_props(struct evdev_device *device)
struct wheel_angle angles;
const char *wheel_count = "MOUSE_WHEEL_CLICK_COUNT";
const char *wheel_angle = "MOUSE_WHEEL_CLICK_ANGLE";
const char *hwheel_count = "MOUSE_WHEEL_CLICK_COUNT_HORIZONTAL";
const char *hwheel_angle = "MOUSE_WHEEL_CLICK_ANGLE_HORIZONTAL";
/* CLICK_COUNT overrides CLICK_ANGLE */
if (evdev_read_wheel_click_count_prop(device, wheel_count, &angles.y) ||
evdev_read_wheel_click_prop(device, wheel_angle, &angles.y)) {
evdev_log_debug(device,
"wheel: vert click angle: %.2f\n", angles.y);
if (evdev_read_wheel_click_count_prop(device, hwheel_count, &angles.x) ||
evdev_read_wheel_click_prop(device, hwheel_angle, &angles.x)) {
"wheel: horizontal click angle: %.2f\n", angles.y);
} else {
angles.x = angles.y;
// since, src/util-prop-parsers.c : abs(angle) > 360
angles.y = 361;
return angles;
modify src/libinput.c. Find libinput_event_pointer_get_axis_value_discrete function and apply scroll ratio as you wish:
LIBINPUT_EXPORT double
libinput_event_pointer_get_axis_value_discrete(struct libinput_event_pointer *event,
enum libinput_pointer_axis axis)
struct libinput *libinput = event->base.device->seat->libinput;
double value = 0;
require_event_type(libinput_event_get_context(&event->base),
event->base.type,
0.0,
LIBINPUT_EVENT_POINTER_AXIS);
if (!libinput_event_pointer_has_axis(event, axis)) {
log_bug_client(libinput, "value requested for unset axis\n");
} else {
switch (axis) {
case LIBINPUT_POINTER_AXIS_SCROLL_HORIZONTAL:
// x5 ratio for horizontal scrolling
value = event->discrete.x * 5;
break;
case LIBINPUT_POINTER_AXIS_SCROLL_VERTICAL:
// x5 ratio for vertical scrolling
value = event->discrete.y * 5;
break;
return value;
Prepare build directory (dependencies installation required):
meson --prefix=/usr builddir/ -Ddocumentation=false
Compile and install:
ninja -C builddir/ && sudo ninja -C builddir/ install
Verify location:
sudo updatedb
Logout / Login , use.
- 867
- 1
- 8
- 23
For Ubuntu 20.04 LTS I have made good experience with mousewheel.system_scroll_override_on_root_content.enabled set to true. This keeps the mousewheel.min_line_scroll_amount intact, which is good for precision. You can additionally set the scroll factor higher: mousewheel.system_scroll_override_on_root_content.vertical.factor (default. 200).
Firefox 80 / about:config
- Set
mousewheel.system_scroll_override_on_root_content.enabledtotrue - (optionally) Increase
mousewheel.system_scroll_override_on_root_content.vertical.factor(default. 200)
- 111
I also wanted to increase the mouse scroll wheel acceleration, and not just the absolute speed. This is a feature in MacOSX but not builtin for Xorg (also Wayland) yet.
I implemented such a feature in user space here (mouse-scroll-wheel-acceleration-userspace). This will increase the scroll speed, or accelerate the scroll speed. You would just run this in the background, with your preferred options. The code is quite simple Python code, and should be easy to modify as well.
- 2,817
Even if the unplug/plug trick does fix the issue this is not a really good solution
One solution I found is to add
xinput set-prop 10 'Evdev Scrolling Distance' 10 10 10
at the end of my .profile file (or wherever it gets executed once per graphical login)
In the case of my Microsoft mouse the default values were 1 1 1 which are way too sensitive.
10 10 10 are right for me.
I didn't take the time to see what each number actually means
- 8,015
- 16
- 63
- 115
