I can't find anything for this, I use a dell USB mouse, no special buttons or hardware, I regularly need to be able to scroll by couple-pixel distances, mostly in chrome, but for my sanity the ability to do it in everything else would be extremely helpful, according to other questions I found, I can't just change the number of scroll lines and the middle-click scroll is apparently taken up by xclipboard or something,
What do I do? I've run out of ideas, I just came from windows, where this was solved by autoscroll on middle-click and drag, and the ability of my laptop in particular to scroll by 1 pixel in any direction by using the numberpad arrows system-wide.
Do you want to Increase Mouse-key acceleration?
Firstly open a terminal window and type the following to install the xkbset package:
sudo apt-get install xkbset
A simple one line command can then be used to configure the acceleration:
xkbset ma [delay] [interval] [time to max] [max speed] [curve]
For those new to command-line interfaces, the brackets imply that they need to be replaced by a numerical value, tailored to suite a particular use. I have recently used the following for my configuration:
xkbset ma 60 10 10 20 10
Korkel
  • 1,168
Try this app for chrome, it should do what you want via ctrl+leftclick.
Tim
  • 33,500
The Chromium Wheel Smooth Scroller extension gives you fine-grained control over how your mouse wheel and keyboard perform scrolling in Google Chrome and the Chromium browser. Unfortunately setting a low step size will not provide a very fast maximum speed, so you may need to sacrifice your keyboard to perform small scrolls, and keep your mouse for general scrolling.
The app suggested by Tim is likely to be more useful.
Another option is this Auto Scroll Keys userscript (which I have worked on but did not initially create). But that's not trivial to install if you don't already have TamperMonkey.
Some discussion about adjusting Firefox scroll speed can be found here. You should be able to reduce the speed using the same techniques.
Gnome-wide settings are also discussed on that page, but unfortunately the feature doesn't appear to be available just yet (2015).
joeytwiddle
  • 2,009
