My 12.04 x64 system won't boot into GUI, but I can still use virtual console with my own account, so apparently it's the Windows Management System that's causing it, how can I reinstall it from tty, what's the apt-get command?
Asked
Active
Viewed 7.9e+01k times
82
Braiam
- 69,112
Jack Mayerz
- 1,687
94
Please refer to ServerGUI.
The answer is to use this commands in terminal:
sudo apt-get install xorg openbox
Eric Carvalho
- 55,453
user134379
- 958
- 7
- 4
30
X11 Client Installation
To do this, install the xauth pachage, then install the applications you need, and apt-get will bring in other packages as needed to satisfy the dependencies.
sudo apt-get install xauth
X11 Server Installation
To install a minimal X11 on Ubuntu Server Edition enter the following:
sudo apt-get install openbox
10
If you certainly have run into this problem , type in the following commands:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install fglrx
sudo apt-get install xserver-xorg-core
sudo apt-get install ubuntu-desktop
and you are good to go. The statements from top to bottom are dependencies to the statements after them.
Artur Meinild
- 31,035
SHAYAN
- 109
do nothing. just relax. And if you don't find out how to install, I will tell you:
sudo apt-get update
Ravexina
- 57,256
I solved the problem using:
sudo aptitude install xorg
then say 'yes' to the updates.
heemayl
- 93,925
Rohit Gupta
- 51
