I'm fairly new to Linux, excuse me if I'm missing something obvious.
Until recently, I used a GTX 750TI for my Server (Ubuntu 20.4 LTS), but then a friend of mine needed a GPU. I took the GPU out, since I still have the integrated graphics from Intel (i7 6700), which should have been more than enough for a headless server.
When I restarted the Server, I only got a black screen after login via XRDP. I connected the Server to a screen and noticed that I'm using LLVMPIPE instead of the HD630. I searched for many fixes online, and tried this one:
https://www.computersnyou.com/4945/re-install-xorg-xserver-completely-ubuntu/
I followed these steps and then rebooted my system:
sudo apt-get purge xorg "xserver-*"
sudo apt-get purge lightdm plymouth
sudo rm -rf /etc/X11/xorg
sudo apt-get autoremove
Now I'm stuck in some kind of grey screen with different colors after the BIOS screen. I tried rebooting, unplugging the power... but that obviously didn't help.
The Problem is definitely caused by me uninstalling XORG, but I have no idea how I should install it now since I can't access the console.
Where should I go from here?
The worst thing you can do is to remove Xorg. This is the "glue" that keeps everything graphical together. In order to get your device running you need to reinstall Xorg and remove all NVIDIA Drivers (which block the use of your Intel GPU).(by using sudo apt purge nvidia*)
Get your display manager back:
sudo apt install lightdm plymouth
Then you need Xorg:
sudo apt install Xorg*
see here for more infos.
Just to explain: those packages are GPU agnostic. You need them if you want a decent graphical environment, no matter what GPU you are using. The Xorg server will provide you with all the drivers you need to get a GPU running. Without you're doomed.
Since you've removed all the important packages, you'd need a desktop environment. Do get a decent one:
sudo apt install xfwm4
Still - I would try to save my data unto an external disk and setup the system new with a live disk. That's the reason why there are distros out there. They know how to keep the different parts together.
Linux is really good using the Intel GPU. But it needs a chance to use them. Without Xorg, you won't have graphics, just text.
kanehekili
  • 7,426
