Possible Duplicate:
Access Windows 7 Files from Ubuntu 12.04
I am using ubuntu 12.04 side by side with windows 7. I installed ubuntu in a drive which also contained windows folder. But the drive is not shown in ubuntu! How do i access that folder?
Thank you.
pranphy
  • 1,668
it is located in /host folder.
Go to the 'file system' then you will find host directory. It contains all the files of windows.
Deepak
  • 771
You can find very detailed instructions here. Alternatively, try these solutions:
  1. solution. Install a program called ntfs-config, either from Ubuntu software centre, or by typing
    sudo apt-get install ntfs-config
    Run that program, select the disk to mount.
  2. solution, using command line:
    First, find out what the ID of your NTFS disk is. Run this program from command line:
    sudo blkid
    That will a line for each partition, showing the volume UUID as well as the format. One of these should have the format "ntfs". This is your Windows partition. Now run
    udisks --mount /dev/disk/by-uuid/XXXXX
    where XXXXX is the UID of your Windows partition.
  3. solution, mounting automatically at boot time: read this answer.
Please, however, note that you cannot mount hibernated Windows partitions.
Do not hesitate to come back if you have problems with any of these.
January
  • 37,208
