I'm new to Ubuntu, so can any of you give me a guide of how I can access my windows 7 files from my Ubuntu 12. I installed it using Wubi. Looked around everywhere but failed.
In my case i just go to the Home Folder-->> File System-->> host-->> Users
Just open up terminal and write sudo fdisk -l. then try figuring out which partition is your c drive. and then just mount the partition as:
sudo mkdir /storage
sudo mount /dev/sda3 /storage //in case dev3 is your c drive.
Why not enable mount of the windows partition on boot time? There is a utility called ntfs-config which mounts your windows partition on boot time. install it as sudo apt-get install ntfs-config and enable mount at boot as
Seth
  • 59,332
ashutosh
  • 1,302
Well, if you installed Wubi on the partition where are the files you want to access, in should be mounted under /host directory. If not, just launch the Disk Utility, find the wanted partition, and click the mount button. Partition should show up in Nautilus right now.
LiquidPL
  • 218
