92
I have been using Firefox for a long time in Ubuntu, I downloaded some add-ons but it made firefox extremely slow, even if I remove them nothing will change.
I tried to remove Firefox also, but re-installing it will somehow recover the same Firefox I had- it seems it write some info somewhere that even if you remove Firefox, it will keep them.
Moreover, I am not able to use see any flash videos or website with Firefox(chrome works fine).. Honestly I tampered with plug-in settings in Firefox that this happened. But right now I can't do anything to overwrite the setting...
My question is how I can remove Firefox in a way to remove any previous traces and re-install a new version like for the first time?
gsamaras
  • 615
Hossein
  • 1,777
9 Answers9
142
Delete Firefox and all it's data:
Thanks are also due to snap question and its answers and comments
I think this can be done in six easy steps, please edit my answer - or tell me to - if it's not complete:
Run type firefox. You will either get
  • firefox is /usr/bin/firefox or
  • firefox is /snap/bin/firefox
If you get
Output Firefox has been installed by
firefox is /usr/bin/firefox apt
firefox is /snap/bin/firefox snap
Apt and snap are ways to install packages. (package managers) If the answer is apt, follow these steps . Steps for snap are after it.
Steps to follow if apt
  1. Run sudo apt-get purge firefox Unless you are serious about data privacy this step should be enough
  2. Delete .mozilla/firefox/ in your home directory, should it still be there
  3. Delete .macromedia/ and .adobe in your home directory, these can contain "Flash Cookies" stored by the browser. The same is true, if applicable, for Silverlight (Moonlight) and other plugins, they can allow websites to store data on your computer.
  4. Delete /etc/firefox/, this is where your preferences and user-profiles are stored
  5. Delete /usr/lib/firefox/ should it still be there
  6. Delete /usr/lib/firefox-addons/ should it still be there
Mind the periods in front of file- and directory names: They indicate a hidden directory. You can tell your File Browser to show them by pressing Ctrl+H.
The 4th and 5th step must be done with superuser privileges. To start a the File Browser as a superuser, press Alt+F2 and enter gksu nautilus.
Finally, restart your computer to get rid of all temporary files. This should remove all traces of firefox ever being there.
Important:
  • Don't rely on this method if you've got sensitive information to protect! Deleting a file, in most cases, only means deleting a reference to it. The raw data will still be on your hard drive, and the proverbial bond-villain will be able to recover them. I'm only mentioning this in case it's applicable to anybody who reads this. The only way to really get rid of data is to shred the hard drive to bits.
Steps to follow if snap
  • sudo snap remove firefox
26
All the answers given so far are way too drastic. You don't need to apt-get purge firefox or rm -rf ~/.mozilla to get what you want.
Here's the thing. Firefox doesn't store any user data in itself. What it does instead is create what's known as a "user profile" -- a directory in your home directory -- and store all your data in there. And by data I mean everything -- add-ons, themes, browsing history, stored passwords, and on and on. (The actual location of your profiles in the filesystem varies by OS; on Ubuntu and other Linuxes, it's generally in .mozilla/firefox in your home directory.) Data in the user profile is completely separate from the Firefox application itself, so removing Firefox via apt-get or the like won't delete the profile data; when you reinstall Firefox later, it'll just look up your profile and reload it all, which can be frustrating if you don't realize what's going on.
When you first use Firefox, it silently creates a default profile for you, and uses that profile from that day onward. But you don't have to use that profile. Firefox supports multiple profiles, and you can switch back and forth between them at will. This means that to get Firefox back to the way it was the day you first installed it, you don't have to touch the Firefox binaries at all -- all you have to do is create a new, empty profile, and use it instead of your old, cluttered one. Restart Firefox and it'll be like you never ran it before.
Here's how to create a new FF profile in Ubuntu:
  • Close all running Firefox windows
  • Open a console window (profile management is only accessible via the command line)
  • Run the following command at the prompt: firefox -ProfileManager
  • This will launch the Firefox Profile Manager -- a dialog box that looks like this:
Firefox profile manager
Yours will probably only have one profile listed -- that's your current, default profile, with all your add-ons and other stuff. It'll have a name that starts with a string of random characters; that's because FF had to come up with a name for it when it automatically created the profile, so it just used a random string.
  • Click the "Create Profile" button. This will launch a wizard walking you through defining a new, empty profile. When that process is complete you'll be returned to the Profile Manager dialog box, now with two profiles listed, your old one and your new one.
  • Select your newly created profile.
  • Optional: if you want Firefox to use your new, empty profile from now on by default, check the "Don't ask at startup" box. If you'd prefer FF to prompt you for which profile you want to use each time you run it, leave that box unchecked.
  • Click "Start Firefox".
Now Firefox will restart, completely fresh and new as the first day you downloaded it. Problem solved. And if you ever need to retrieve something from your old profile, like your old bookmarks, say, all your old data is archived in your old profile, so you can safely retrieve it later.
  • Open Ubuntu Software Application enter image description here
  • Go to Installed
  • Search for Firefox
  • Click on Remove. enter image description here
Morse
  • 171
First of all, remove Firefox and all of its configuration files by typing in:
Also, make sure that the ~/.mozilla directory (which contains Firefox' configuration files) is deleted:
rm -rf ~/.mozilla
It might even not be necessary to reinstall Firefox, just remove the ~/.mozilla directory (step two) and restart Firefox, and it should be just as if you just installed it.
Freyja
  • 4,291
If you get
Output Firefox has been installed by Steps
firefox is /usr/bin/firefox apt sudo apt purge firefox
firefox is /snap/bin/firefox snap sudo snap purge firefox
You can try to delete the ~/.mozilla folder which contains all the browser's settings.
Pavlos G.
  • 8,954
This will do the whole trick, removing all packages and files,
sudo apt-get --purge autoremove firefox
"autoremove" purges everything that once was needed to install or run a program.
Also remember to update or dist-update (this last one is my favorite), after you removed firefox or any other software. Some users recommend doing a simple update before removing or installing programs.
hvizcarra
You only need to type:
and then type y for "Yes", and Enter
That took care of everything. Firefox is now off of my computer and Google Chrome is doing a great job.
MrVaykadji
  • 5,965
I want to give my laptop to my mother (and yes, my mama will use Ubuntu! :P), so I wanted to make a fresh start for Firefox, and in , I did this:
rm -rf ~/.mozilla/firefox/
gsamaras
  • 615
